Cisco CTI Service won't start after Windows 10 update
Rew Waltman
Cisco CUCM 12.5 - UCCX 12.5 - Windows 10.
We are using Spok Medicall in our call center. The agents use a modified version of CAD or Finesse to control the phones. After a Windows update we noticed that the CTI service will not start. I have uninstalled and reinstalled the TAPI and CTI software but still no luck.
Anyone else have a similar problem and a solution?
Sadav Ansari
Are you able to  start or stops other services from your machine ? If yes then raise a case on Microsoft support forum.
If no then it seems like access issue, check your privileges may be you need to login as a admin on machine to start or stops services.
Pls rate if its “Helpful”. If this answered your question pls click “Accept as Solution”;
Sadav Ansari
