07-25-2016 08:54 AM - edited 03-17-2019 07:37 AM
Hi All,
We have issue with outbound DTMF calls. Although this issue is intermittent but service provider saying we don't support delayed/late offer SDP . They saying we need to send SDP in initial invite Could some tell me how to enable/send SDP in initial invite? Are they talking about early offer? We have following setup
CiscoPhone --> CUCM --> H323 --> CUBE --> SIP --> ITSP
No SDP is in sent invite
Sent:
INVITE sip:03031231177@10.128.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.160.134.99:5060;branch=z9hG4bK18B281671
To: <sip:03031231177@10.168.0.1>
Date: Mon, 25 Jul 2016 13:21:26 GMT
Call-ID: 865729D6-51A111E6-9DABB464-C9AE0C71@10.160.134.99
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2161385647-1444045177-1497997831-0175408263
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1469452886
Contact: <sip:62161@10.160.134.99:5060>
Expires: 180
Allow-Events: telephone-event
P-Asserted-Identity: <sip:62161@10.160.134.99>
Content-Length: 0
Privacy: id
07-25-2016 09:39 AM
enable the Fast Start on the H.323 GW on CUCM side, Yes they are referring to EO(Early offer) which contain SDP info
refer to below for inter-networking doc
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/vb_8241.html
Protocol
In Leg
Out Leg
Support
H.323-to-SIP |
Fast Start |
Early-Offer |
Bi-Directional |
Slow Start |
Delayed-Offer |
Bi-Directional |
07-25-2016 11:08 AM
Hi Nadeem, thanks for your reply. After adding that command on dial-peer level still DTMF not working also I am not seeing any difference in the logs still no sdp in initial invite. I mean not sdp and pay load 101
dial-peer voice 49 voip
description *** Outbound LANDLINE calls to ITSP ***
destination-pattern 03031231177
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip asserted-id pai
voice-class sip early-offer forced
voice-class sip profiles 4
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
ip qos dscp cs4 media
ip qos dscp cs3 signaling
no vad
debug ccsip message
debug voice ccapi inout
192856: Jul 25 17:52:44.390: //-1/808392952700/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=62161
----- ccCallInfo IE subfields -----
cisco-ani=62161
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=903031231177
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
192857: Jul 25 17:52:44.390: //-1/808392952700/CCAPI/cc_api_call_setup_ind_common:
Interface=0x13BFF73C, Call Info(
Calling Number=62161,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=903031231177(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=101, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=19811
192858: Jul 25 17:52:44.390: //-1/808392952700/CCAPI/ccCheckClipClir:
In: Calling Number=62161(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
192859: Jul 25 17:52:44.390: //-1/808392952700/CCAPI/ccCheckClipClir:
Out: Calling Number=62161(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
192860: Jul 25 17:52:44.390: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
192861: Jul 25 17:52:44.390: :cc_get_feature_vsa malloc success
192862: Jul 25 17:52:44.390: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
192863: Jul 25 17:52:44.390: cc_get_feature_vsa count is 3
192864: Jul 25 17:52:44.390: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
192865: Jul 25 17:52:44.390: :FEATURE_VSA attributes are: feature_name:0,feature_time:51637984,feature_id:14816
192866: Jul 25 17:52:44.390: //19811/808392952700/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=62161(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=903031231177(TON=Unknown, NPI=Unknown))
192867: Jul 25 17:52:44.390: //19811/808392952700/CCAPI/cc_process_call_setup_ind:
Event=0x2E75D28
192868: Jul 25 17:52:44.390: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 903031231177
192869: Jul 25 17:52:44.390: //19811/808392952700/CCAPI/ccCallSetContext:
Context=0x144914BC
192870: Jul 25 17:52:44.390: //19811/808392952700/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 19811 with tag 101 to app "_ManagedAppProcess_Default"
192871: Jul 25 17:52:44.390: //19811/808392952700/CCAPI/ccCallProceeding:
192872: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=49, Params=0xA90BEAC, Progress Indication=NULL(0)
192873: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccCheckClipClir:
192874: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccCheckClipClir:
192875: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccCallSetupRequest:
Destination Pattern=03031231177, Called Number=03031231177, Digit Strip=FALSE
192876: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccCallSetupRequest:
Called Number=03031231177(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=62161, Final Destination Flag=TRUE,
Guid=80839295-EC51-6179-2700-BF070A748487, Outgoing Dial-peer=49
192877: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=62161
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=03031231177
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
192878: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x13C0C234, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=62161,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=03031231177(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=49, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
192879: Jul 25 17:52:44.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
192880: Jul 25 17:52:44.394: :cc_get_feature_vsa malloc success
192881: Jul 25 17:52:44.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
192882: Jul 25 17:52:44.394: cc_get_feature_vsa count is 4
192883: Jul 25 17:52:44.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
192884: Jul 25 17:52:44.394: :FEATURE_VSA attributes are: feature_name:0,feature_time:51638208,feature_id:14817
192885: Jul 25 17:52:44.394: //19812/808392952700/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
192886: Jul 25 17:52:44.394: //19812/808392952700/CCAPI/ccCallSetContext:
Context=0xA90BE5C
192887: Jul 25 17:52:44.394: //19811/808392952700/CCAPI/ccSaveDialpeerTag:
192888: Jul 25 17:52:44.394: //19812/808392952700/CCAPI/cc_api_call_proceeding:
Interface=0x13C0C234, Progress Indication=NULL(0)
192889: Jul 25 17:52:44.394: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:03031231177@192.128.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.128.0.2:5060;branch=z9hG4bK1A3F42571
To: <sip:03031231177@192.128.0.2>
Date: Mon, 25 Jul 2016 17:52:44 GMT
Call-ID: 6C9D01DD-51C711E6-A9DCB464-C9AE0C71@172.128.0.2
Min-SE: 1800
Cisco-Guid: 2156106389-3964756345-0654360327-0175408263
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1469469164
Contact: <sip:62161@172.128.0.2:5060>
Expires: 180
P-Asserted-Identity: <sip:62161@172.128.0.2>
Content-Length: 0
Privacy: id
192890: Jul 25 17:52:44.402: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
192891: Jul 25 17:52:44.546: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Require: 100rel
RSeq: 1
To: <sip:03031231177@192.128.0.2>;tag=3678457964-539716
CSeq: 101 INVITE
Allow: UPDATE,PRACK,INFO,NOTIFY,REGISTER,OPTIONS,BYE,INVITE,ACK,CANCEL
Contact: <sip:03031231177@192.128.0.2:5060>
Content-Type: application/sdp
Accept: application/sdp
Content-Length: 162
v=0
o=MSX9 912414279045144647 1 IN IP4 192.128.0.2
s=sip call
c=IN IP4 10.128.0.2
t=0 0
a=sendrecv
m=audio 8304 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=sendrecv
192892: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/cc_api_event_indication:
Event=91, Call Id=19812
192893: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
192894: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=19812,
Caps(Codec=0x2, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
192895: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
192896: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/cc_api_call_cut_progress:
Interface=0x13C0C234, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
Cause Value=0
192897: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/cc_api_call_cut_progress:
Call Entry(Responsed=TRUE)
192898: Jul 25 17:52:44.546: //19811/808392952700/CCAPI/ccGetMediaClassTag:
media class tag 0
192899: Jul 25 17:52:44.546: //19811/808392952700/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
192900: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/ccGetMediaClassTag:
media class tag 0
192901: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/ccSetMediaclassIp2ipTags:
192902: Jul 25 17:52:44.546: //19811/808392952700/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
192903: Jul 25 17:52:44.546: //19812/808392952700/CCAPI/ccGet_xc_nr_asp_info:
192904: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
192905: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccCallCutProgress:
192906: Jul 25 17:52:44.550: //19812/808392952700/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
192907: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x4D63, gcid=0-0-0-0, tag=0x0)
192908: Jul 25 17:52:44.550: //19812/808392952700/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x4D64, gcid=0-0-0-0, tag=0x0)
192909: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFF, Call Id1=19811, Call Id2=19812, Tag=0x0
192910: Jul 25 17:52:44.550: //19811/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
192911: Jul 25 17:52:44.550: cc_api_get_xcode_stream : 4819
192912: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/cc_api_bridge_done:
Conference Id=0x198C, Source Interface=0x13BFF73C, Source Call Id=19811,
Destination Call Id=19812, Disposition=0x0, Tag=0x0
192913: Jul 25 17:52:44.550: //19812/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
192914: Jul 25 17:52:44.550: cc_api_get_xcode_stream : 4819
192915: Jul 25 17:52:44.550: //19812/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
192916: Jul 25 17:52:44.550: cc_api_get_xcode_stream : 4819
192917: Jul 25 17:52:44.550: //19812/808392952700/CCAPI/cc_api_bridge_done:
Conference Id=0x198C, Source Interface=0x13C0C234, Source Call Id=19812,
Destination Call Id=19811, Disposition=0x0, Tag=0x0
192918: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/cc_generic_bridge_done:
192919: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x198C, Destination Call Id=19812)
192920: Jul 25 17:52:44.550: //19812/808392952700/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x198C, Destination Call Id=19811)
192921: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccConferenceCreate:
192922: Jul 25 17:52:44.550: confID:0x198C; callEntry1 callID1:0x4D63, type:1; callEntry2 callID2:0x4D64, type:3
192923: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x198C, Call Id1=19811, Call Id2=19812
192924: Jul 25 17:52:44.550: //19811/808392952700/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=19811
192925: Jul 25 17:52:44.550: //19812/808392952700/CCAPI/cc_api_get_called_ccm_detected:
192926: Jul 25 17:52:44.558: //19811/808392952700/CCAPI/cc_api_caps_ind:
Destination Interface=0x13C0C234, Destination Call Id=19812, Source Call Id=19811,
Caps(Codec=0x2, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
192927: Jul 25 17:52:44.558: //19811/808392952700/CCAPI/cc_api_caps_ind:
192928: Jul 25 17:52:44.558: //19811/808392952700/CCAPI/ccGetMediaClassTag:
media class tag 0
192929: Jul 25 17:52:44.558: //19811/808392952700/CCAPI/ccSetMediaclassIp2ipTags:
192930: Jul 25 17:52:44.558: //19812/808392952700/CCAPI/ccGetMediaClassTag:
media class tag 0
192931: Jul 25 17:52:44.558: //19812/808392952700/CCAPI/ccSetMediaclassIp2ipTags:
192932: Jul 25 17:52:44.558: //19811/808392952700/CCAPI/ccGet_xc_nr_asp_info:
192933: Jul 25 17:52:44.558: //19812/808392952700/CCAPI/ccGet_xc_nr_asp_info:
192934: Jul 25 17:52:44.562: //19812/808392952700/CCAPI/cc_api_caps_ack:
Destination Interface=0x13BFF73C, Destination Call Id=19811, Source Call Id=19812,
Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
192935: Jul 25 17:52:44.562: //19811/808392952700/CCAPI/cc_api_caps_ack:
Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0x0), Fax Version:=0, Vad=Invalid(0x0),
Modem=OFF(0x0), Codec Bytes=0, Signal Type=0, Seq Num Start=0)
192936: Jul 25 17:52:44.562: //19811/808392952700/CCAPI/cc_api_event_indication:
Event=177, Call Id=19811
192937: Jul 25 17:52:44.562: //19811/808392952700/CCAPI/cc_api_event_indication:
192938: Jul 25 17:52:44.562: //19812/808392952700/CCAPI/cc_api_event_indication:
Event=178, Call Id=19812
192939: Jul 25 17:52:44.562: //19812/808392952700/CCAPI/cc_api_event_indication:
192940: Jul 25 17:52:44.566: //19811/808392952700/CCAPI/cc_api_event_indication:
Event=178, Call Id=19811
192941: Jul 25 17:52:44.566: //19811/808392952700/CCAPI/cc_api_event_indication:
192942: Jul 25 17:52:44.566: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:03031231177@192.128.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.128.0.2:5060;branch=z9hG4bK1A3F58B2
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 176
v=0
o=CiscoSystemsSIP-GW-UserAgent 4832 8827 IN IP4 172.128.0.2
s=SIP Call
c=IN IP4 172.128.0.2
t=0 0
m=audio 29684 RTP/AVP 8
192943: Jul 25 17:52:44.582: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
192944: Jul 25 17:52:47.411: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
Require: 100rel
RSeq: 2
CSeq: 101 INVITE
Content-Length: 0
192945: Jul 25 17:52:47.411: //19812/808392952700/CCAPI/cc_api_call_cut_progress:
Interface=0x13C0C234, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255),
Cause Value=0
192946: Jul 25 17:52:47.411: //19812/808392952700/CCAPI/cc_api_call_cut_progress:
192947: Jul 25 17:52:47.411: //19811/808392952700/CCAPI/ccCallProgIndProgress:
192948: Jul 25 17:52:47.411: //19812/808392952700/CCAPI/cc_api_get_called_ccm_detected:
192949: Jul 25 17:52:47.411: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.128.0.2:5060;branch=z9hG4bK1A3F62348
CSeq: 103 PRACK
RAck: 2 101 INVITE
Max-Forwards: 70
Content-Length: 0
192950: Jul 25 17:52:47.423: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
192951: Jul 25 17:52:47.883: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Session-Expires: 3600;refresher=uas
Require: timer
CSeq: 101 INVITE
Content-Length: 162
v=0
s=sip call
c=IN IP4 10.128.0.2
t=0 0
a=sendrecv
a=sendrecv
192952: Jul 25 17:52:47.883: //19812/808392952700/CCAPI/cc_api_call_connected:
Interface=0x13C0C234, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
192953: Jul 25 17:52:47.883: //19812/808392952700/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
192954: Jul 25 17:52:47.883: //19812/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
192955: Jul 25 17:52:47.883: call_info mainst_callID:0x4D64, peer_callID:0x4D63, confID:0x198C, spi_type:4, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
192956: Jul 25 17:52:47.883: //19811/808392952700/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
192957: Jul 25 17:52:47.883: //19812/808392952700/CCAPI/cc_api_get_called_ccm_detected:
192958: Jul 25 17:52:47.883: //19811/808392952700/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
192959: Jul 25 17:52:47.883: //19811/808392952700/CCAPI/ccCallNotify:
192960: Jul 25 17:52:47.883: //19812/808392952700/CCAPI/cc_api_get_called_ccm_detected:
192961: Jul 25 17:52:47.883: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.128.0.2:5060;branch=z9hG4bK1A3F71A1E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
192962: Jul 25 17:52:48.923: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 1 to dstCallId 0x4D64
192963: Jul 25 17:52:48.923: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
Check DTMF relay digit begin for 3way conf
192964: Jul 25 17:52:48.999: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192965: Jul 25 17:52:48.999: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
192966: Jul 25 17:52:51.775: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
192967: Jul 25 17:52:51.775: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
192968: Jul 25 17:52:51.851: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192969: Jul 25 17:52:51.851: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
192970: Jul 25 17:52:52.231: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 2 to dstCallId 0x4D64
192971: Jul 25 17:52:52.231: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
192972: Jul 25 17:52:52.307: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192973: Jul 25 17:52:52.307: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
192974: Jul 25 17:52:52.763: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 3 to dstCallId 0x4D64
192975: Jul 25 17:52:52.763: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
192976: Jul 25 17:52:52.839: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192977: Jul 25 17:52:52.839: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
192978: Jul 25 17:52:53.215: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 6 to dstCallId 0x4D64
192979: Jul 25 17:52:53.215: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
192980: Jul 25 17:52:53.291: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192981: Jul 25 17:52:53.291: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
192982: Jul 25 17:52:53.715: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 5 to dstCallId 0x4D64
192983: Jul 25 17:52:53.715: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
192984: Jul 25 17:52:53.791: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192985: Jul 25 17:52:53.791: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
192986: Jul 25 17:52:54.155: //19811/808392952700/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 4 to dstCallId 0x4D64
192987: Jul 25 17:52:54.155: //19811/808392952700/CCAPI/cc_relay_digit_begin_for_3way_conference:
192988: Jul 25 17:52:54.231: //19811/808392952700/CCAPI/cc_api_call_digit_end:
192989: Jul 25 17:52:54.231: //19811/808392952700/CCAPI/cc_relay_digit_end_for_3way_conference:
192990: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x13BFF73C, Call Id=19811
192991: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
192992: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/ccConferenceDestroy:
Conference Id=0x198C, Tag=0x0
192993: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/ccConferenceDestroy:
192994: Jul 25 17:52:55.555: confID:0x198C; callEntry1 callID1:0x4D63, type:1; callEntry2 callID2:0x4D64, type:3
192995: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/cc_api_bridge_drop_done:
192996: Jul 25 17:52:55.555: //19812/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
192997: Jul 25 17:52:55.555: cc_api_get_xcode_stream : 4819
192998: Jul 25 17:52:55.555: //19811/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
192999: Jul 25 17:52:55.555: cc_api_get_xcode_stream : 4819
193000: Jul 25 17:52:55.555: //19812/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
193001: Jul 25 17:52:55.555: cc_api_get_xcode_stream : 4819
193002: Jul 25 17:52:55.555: //19812/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
193003: Jul 25 17:52:55.555: cc_api_get_xcode_stream : 4819
193004: Jul 25 17:52:55.555: //19812/808392952700/CCAPI/cc_api_bridge_drop_done:
193005: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/cc_generic_bridge_done:
193006: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
193007: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
193008: Jul 25 17:52:55.555: //19811/808392952700/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
193009: Jul 25 17:52:55.555: //19812/808392952700/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
193010: Jul 25 17:52:55.555: //19812/808392952700/CCAPI/ccCallDisconnect:
193011: Jul 25 17:52:55.559: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:03031231177@192.128.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.128.0.2:5060;branch=z9hG4bK1A3F81FFA
Max-Forwards: 70
Timestamp: 1469469175
CSeq: 104 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=383,OS=61280,PR=549,OR=87840,PL=0,JI=0,LA=0,DU=7
Content-Length: 0
193012: Jul 25 17:52:55.559: //19811/808392952700/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x13BFF73C, Tag=0x0, Call Id=19811,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
193013: Jul 25 17:52:55.559: //19811/808392952700/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
193014: Jul 25 17:52:55.559: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
193015: Jul 25 17:52:55.559: :cc_free_feature_vsa freeing 313EED8
193016: Jul 25 17:52:55.559: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
193017: Jul 25 17:52:55.559: vsacount in free is 3
193018: Jul 25 17:52:55.571: //19812/808392952700/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 BYE
Content-Length: 0
193019: Jul 25 17:52:55.571: //19812/808392952700/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x13C0C234, Tag=0x0, Call Id=19812,
193020: Jul 25 17:52:55.571: //19812/808392952700/CCAPI/cc_api_call_disconnect_done:
193021: Jul 25 17:52:55.571: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
193022: Jul 25 17:52:55.571: :cc_free_feature_vsa freeing 313EFB8
193023: Jul 25 17:52:55.571: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
193024: Jul 25 17:52:55.571: vsacount in free is 2
CDC-CUBE#
;tag=1682B2B8-1A74
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Privacy: id
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
Require: 100rel
RSeq: 1
CSeq: 101 INVITE
Content-Length: 162
v=0
s=sip call
c=IN IP4 10.128.0.2
t=0 0
a=sendrecv
a=sendrecv
Cause Value=0
media class tag 0
media class tag 0
media class tag 0
media class tag 0
Sent:
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 176
v=0
s=SIP Call
t=0 0
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Received:
Require: 100rel
RSeq: 2
CSeq: 101 INVITE
Content-Length: 0
Cause Value=0
Sent:
CSeq: 103 PRACK
RAck: 2 101 INVITE
Max-Forwards: 70
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
Received:
SIP/2.0 200 OK
Require: timer
CSeq: 101 INVITE
Content-Length: 162
v=0
s=sip call
c=IN IP4 10.128.0.2
t=0 0
a=sendrecv
a=sendrecv
Connection Handle=0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 104 BYE
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 104 BYE
Content-Length: 0
CDC-CUBE#
07-25-2016 11:14 AM
You need to enable fast start on h323 gateway which requires MTP allocation checkbox to be selected.
Then configure MTP on IOS CUBE.
Also, uncheck 'Wait for Far End H.245 Terminal Capability Set' from the gateway.
07-26-2016 01:28 PM
07-26-2016 08:25 PM
Your DTMF on the SIP side of your call is in band, looking at the Early offer SDP,
this means that your incoming H323 dialpeer will need to be configured in accordance with that; rtp-nte
" dtmf-relay rtp-nte "
(see below for a full capability matrix:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/dtmf-relay.html )
07-27-2016 03:29 AM
Dennis, thatnks for your reply. I am using one incoming dial-peer 101. This used for both from ITSP & CUCM incoming calls. I have tried to separate incoming dial from cucm but unfortunatley everytime it uses below dial-peer 101 which is anyways configured as "dtmf-relay rtp-nte"
dial-peer voice 101 voip
description *** Inbound Calls from ITSP ***
translation-profile incoming STD
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
07-27-2016 05:23 PM
Hi All, issue has been resolved by changing the cube mode from h323 to sip with callmanger and now it is sip to sip
However now I am experiencing a wired issue. when I am trying to debug voice ccapi inout I cannot log what I used to see before where I can easily identify what is out going dial peer and what is incoming dial-peer. After changes I cannot see old log as below example
Logs before change (Example)
032227: Jul 25 13:21:02.580: //-1/77F9781C9D97/CCAPI/cc_api_display_ie_subfields:
cisco-username=+442476392352
cisco-ani=sip:+442476392352@10.18.10.1
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:01926353749@10.160.134.198;user=phone
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
032228: Jul 25 13:21:02.584: //-1/77F9781C9D97/CCAPI/cc_api_call_setup_ind_common:
Interface=0x13C0C234, Call Info(
Calling Number=sip:+442476392352@10.128.0.1,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:01926353749@10.60.34.98;user=phone(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=18416
After Changes
Log Buffer (10000 bytes):
538D11E6-A105B464-C9AE0C71, tag=0x0)
637449: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFF, Call Id1=32966, Call Id2=32967, Tag=0x0
637450: Jul 28 00:05:19.027: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637451: Jul 28 00:05:19.027: cc_api_get_xcode_stream : 4819
637452: Jul 28 00:05:19.027: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637453: Jul 28 00:05:19.027: cc_api_get_xcode_stream : 4819
637454: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccConferenceCreate:
637455: Jul 28 00:05:19.027: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=1, dtmf1=6
ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=6,
tx_dynamic_pt1=8, rx_dynamic_pt1=8, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=8, rx_dynamic_pt2=8, codec_mode2=0, params_bitmap2 =0
637456: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccGetMediaClassTag:
media class tag 0
637457: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccSetMediaclassIp2ipTags:
637458: Jul 28 00:05:19.027: //32967/F66BB8800012/CCAPI/ccGetMediaClassTag:
media class tag 0
637459: Jul 28 00:05:19.027: //32967/F66BB8800012/CCAPI/ccSetMediaclassIp2ipTags:
637460: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccGet_xc_nr_asp_info:
637461: Jul 28 00:05:19.027: //32967/F66BB8800012/CCAPI/ccGet_xc_nr_asp_info:
637462: Jul 28 00:05:19.027: //32966/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
xcoder inserted for preferred features w/ mask 0x0
637463: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccConferenceCreate:
delay media to slow start case, codec negotation is not done
637464: Jul 28 00:05:19.027: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637465: Jul 28 00:05:19.027: cc_api_get_xcode_stream : 4819
637466: Jul 28 00:05:19.027: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637467: Jul 28 00:05:19.027: cc_api_get_xcode_stream : 4819
637468: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/cc_api_bridge_done:
Conference Id=0x2ACF, Source Interface=0x13C0C234, Source Call Id=32966,
Destination Call Id=32967, Disposition=0x0, Tag=0x0
637469: Jul 28 00:05:19.027: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637470: Jul 28 00:05:19.027: cc_api_get_xcode_stream : 4819
637471: Jul 28 00:05:19.027: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637472: Jul 28 00:05:19.027: cc_api_get_xcode_stream : 4819
637473: Jul 28 00:05:19.027: //32967/F66BB8800012/CCAPI/cc_api_bridge_done:
Conference Id=0x2ACF, Source Interface=0x13C0C234, Source Call Id=32967,
Destination Call Id=32966, Disposition=0x0, Tag=0x0
637474: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/cc_generic_bridge_done:
637475: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2ACF, Destination Call Id=32967)
637476: Jul 28 00:05:19.027: //32967/F66BB8800012/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2ACF, Destination Call Id=32966)
637477: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/ccConferenceCreate:
637478: Jul 28 00:05:19.027: confID:0x2ACF; callEntry1 callID1:0x80C6, type:3; callEntry2 callID2:0x80C7, type:3
637479: Jul 28 00:05:19.027: //32966/F66BB8800012/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2ACF, Call Id1=32966, Call Id2=32967
637480: Jul 28 00:05:21.667: //32967/F66BB8800012/CCAPI/cc_api_event_indication:
Event=98, Call Id=32967
637481: Jul 28 00:05:21.667: //32967/F66BB8800012/CCAPI/cc_api_event_indication:
637482: Jul 28 00:05:21.667: //32967/F66BB8800012/CCAPI/cc_api_call_cut_progress:
Cause Value=0
637483: Jul 28 00:05:21.667: //32967/F66BB8800012/CCAPI/cc_api_call_cut_progress:
637484: Jul 28 00:05:21.667: //32966/F66BB8800012/CCAPI/ccCallProgIndProgress:
637485: Jul 28 00:05:22.403: //32967/F66BB8800012/CCAPI/cc_api_call_connected:
Connection Handle=0
637486: Jul 28 00:05:22.403: //32967/F66BB8800012/CCAPI/cc_api_call_connected:
637487: Jul 28 00:05:22.403: //32967/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
637488: Jul 28 00:05:22.403: call_info mainst_callID:0x80C7, peer_callID:0x80C6, confID:0x2ACF, spi_type:4, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
637489: Jul 28 00:05:22.407: //32966/F66BB8800012/CCAPI/ccCallConnect:
637490: Jul 28 00:05:22.407: //32966/F66BB8800012/CCAPI/ccCallConnect:
637491: Jul 28 00:05:22.415: //32966/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
637492: Jul 28 00:05:22.415: call_info mainst_callID:0x80C6, peer_callID:0x80C7, confID:0x2ACF, spi_type:4, media_flo_thru:1, media_passthru:1, num_streams:1, swmtpmsp_present:0
637493: Jul 28 00:05:22.415: //32966/F66BB8800012/CCAPI/cc_api_event_indication:
Event=200, Call Id=32966
637494: Jul 28 00:05:22.415: //32966/F66BB8800012/CCAPI/cc_api_event_indication:
637495: Jul 28 00:05:26.316: //32967/F66BB8800012/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=32967
637496: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x13C0C234, Call Id=32966
637497: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/cc_api_call_disconnected:
637498: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/ccConferenceDestroy:
Conference Id=0x2ACF, Tag=0x0
637499: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/ccConferenceDestroy:
637500: Jul 28 00:05:26.316: confID:0x2ACF; callEntry1 callID1:0x80C6, type:3; callEntry2 callID2:0x80C7, type:3
637501: Jul 28 00:05:26.316: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637502: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637503: Jul 28 00:05:26.316: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637504: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637505: Jul 28 00:05:26.316: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637506: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637507: Jul 28 00:05:26.316: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637508: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637509: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/cc_api_bridge_drop_done:
637510: Jul 28 00:05:26.316: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637511: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637512: Jul 28 00:05:26.316: //32966/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637513: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637514: Jul 28 00:05:26.316: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637515: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637516: Jul 28 00:05:26.316: //32967/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
637517: Jul 28 00:05:26.316: cc_api_get_xcode_stream : 4819
637518: Jul 28 00:05:26.316: //32967/F66BB8800012/CCAPI/cc_api_bridge_drop_done:
637519: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/cc_generic_bridge_done:
637520: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/ccCallDisconnect:
637521: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/ccCallDisconnect:
637522: Jul 28 00:05:26.316: //32967/F66BB8800012/CCAPI/ccCallDisconnect:
637523: Jul 28 00:05:26.316: //32967/F66BB8800012/CCAPI/ccCallDisconnect:
637524: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x13C0C234, Tag=0x0, Call Id=32966,
637525: Jul 28 00:05:26.316: //32966/F66BB8800012/CCAPI/cc_api_call_disconnect_done:
637526: Jul 28 00:05:26.316: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
637527: Jul 28 00:05:26.316: :cc_free_feature_vsa freeing 313FE98
637528: Jul 28 00:05:26.316: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
637529: Jul 28 00:05:26.316: vsacount in free is 1
637530: Jul 28 00:05:26.332: //32967/F66BB8800012/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x13C0C234, Tag=0x0, Call Id=32967,
637531: Jul 28 00:05:26.332: //32967/F66BB8800012/CCAPI/cc_api_call_disconnect_done:
637532: Jul 28 00:05:26.332: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
637533: Jul 28 00:05:26.332: :cc_free_feature_vsa freeing 3141718
637534: Jul 28 00:05:26.332: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Router config is some thing like that
voice-card 0
dspfarm
dsp services dspfarm
no voice hunt unassigned-number
no voice hunt dest-out-of-order
no voice hunt invalid-number
voice service voip
ip address trusted list
ipv4 xxxx 255.255.255.255
address-hiding
mode border-element
media anti-trombone
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
sip
header-passing
error-passthru
asserted-id pai
no update-callerid
early-offer forced
sip-profiles 100
voice class codec 1
codec preference 1 g711alaw
voice class h323 1
h225 timeout tcp establish 3
voice class sip-profiles 4
request INVITE sip-header Privacy add "Privacy: id"
voice class sip-profiles 100
request INVITE sip-header SIP-Req-URI modify "; SIP/2.0" ";user=phone SIP/2.0"
request REINVITE sip-header SIP-Req-URI modify "; SIP/2.0" ";user=phone SIP/2.0"
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
call treatment on
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
call threshold global total-calls low 80 high 95
call spike 100
07-25-2016 11:13 AM
Hi Nadeem, thanks for your reply. After adding that command on dial-peer level still DTMF not working also I am not seeing any difference in logs. I mean not sdp and pay load
voice-class codec 1
dtmf-relay rtp-nte
no vad
Please see attached logs as well
