Cisco CUCM 9.1upgrade hardware setup Error
Hung Wen Cheng
Hi guys,
I upgrade from 9.1.1.20000-5 to 9.1.1.20000-28.
But system show upgrade fail.
Then I reboot Cucm and see the picture.
I reboot Cucm can see the picture. I must select Continue to boot cucm.
How I can resolve this issue?
Thanks.
5 Replies 5
Aman Soi
Hi Wen,
Was CUCM 9.1.1.20000-5  working fine before upgrading ?
What is the exact Hardware u are using MCS or VM ?
regds,
aman
Hi Amanso,
1.Yes, Cucm is working.
2.I use MCS-7825-I5.
Thanks.
Hi Wen,
One more info: Just wanted to know whether CUCM 9.1.1.20000-5 is working fine on 7825-I5  or  are you doing fresh installation on 7825-I5 server by using bootable of 9.1.1.20000-5,restoring backup  and then, upgrading further to 9.1.1.20000-8.
regds,
aman
kg4265@att.com
How was this issue resolved?
Please note issue was resolved by installing VM Tools on CUCM. My issue was with 10.5.
