Cisco CUCM SIP trunk with NEC SV7000
saleem pc
I am working on a Cisco IP Telephony requirement where they need internal calling between their Existing NEC SV7000 IP Telephony with proposed Cisco CUCM 11.x. any one have experience with NEC SV7000 SIP integration, does it support from NEC side. appreciate any advice.
Saleem
Jitender Bhandari
Hi Saleem,
There are no compatibility requirements for this, SIP is peer to peer connection. As long as the other side can Speak SIP as per RFC it would work without any issue.
(Rate if it helps)
JB
Thanks for the quick  update. I am looking for the SIP compatibility from other side ( NEC side ).
So there is no compatibility required from any side, they both have to support SIP, as nog as NEC can do SIP it work work.
(Rate if it helps)
JB
