Cisco CUCM
Harun_Daiya
Hi Everyone
Good Day
I need a suggestion I want to deploy background wallpaper for all the IP Phones.
I've already created and uploaded but thing is I need to select manually from phone to set it and in our office we have more than 300+ active extension so that's not a good idea to do.
could you please tell me if is there anyway to deploy it by any policy or make it default..
I've tried to deploy using common phone profile but it doesn't work. even I've created as per the phone model number.
if anyone knows please lemme know.
Create a common phone profile add the image name on background filed.
Disable the option user can change
apply this profile on all phone.
you will have same background on all phone without change it manually
Response Signature
I’ve tried the same by creating a comman profile still it didnt set to all.
Even I’ve disabled user can change feature too. Is it possible you can
guide me or send me step or any configuration so i can check that
It is outlined in the feature configuration for CM. Chapter: Custom Phone Rings and Backgrounds
Response Signature
