04-24-2015 01:07 PM - edited 03-17-2019 02:47 AM
Cisco DX650 trying to dial SIP URI instead of extension for intercluser user.
DX650 registered to CUCM 9.1.2 in sydney cluster with all users (US + Sydney). Call a US user from directory, tries to call as first.last@<IP of Sydney Sub> instead of extension.
LDAP sync is on with directory URI=mail and telephonenumber=ipphone.
04-28-2015 08:42 AM
Anyone?
05-06-2015 11:39 AM
Did you fix this issue as i have the same problem?
Andy
05-06-2015 11:47 AM
I ended up removing Directory URI integration from LDAP sync as users do not need the SIP URI for extension at this point. Also I found that if you hit the + sign on the contact on Dx650 for 2 seconds, it will show you all the options to call this user like extension, SIP URI etc but unfortunately if SIP URI is there, that is the default method used. Another way to fix this would be to enable ILS and then each cluster will know how to reach across cluster for an off cluster SIP URI.
Hope this helps!
Gaurav
12-14-2015 01:00 AM
Hi in latest firmware 10.2.5.60 you will get both SIP URI and extension display. By Default SIP URI dialing will be there but you can select the extension for dialing if it is defined at end user.
