03-18-2012 08:39 AM - edited 03-16-2019 10:11 AM
I have a sitution where seeking expertise help. I have 2 Gateways and 2 Core Switches connected with Subscriber and Publisher CUCM as shown in the attached pic
VGW1 --> CORE 1 ---> Publisher
VGW2 --> CORE 2 ---> Subscriber
Cores 1 & 2 are HSRP Enabled. and both the Gateways have PRI at each from same provider. And registered as MGCP.
Now if the Core1 fails VGW1 can not see CUCM Cluster and hense the incoming calls are getting silence treatment.
I have 2 interfaces at each VGW routers.
Somehow I want to connect these VGWs with both the cores i.e. G 0/0 to Core 1 and G0/1 to Core 2 of each. Is it possible?
Any help to develop an Idea would be highly appriciable.
Many Thanks!
Nitin
Solved! Go to Solution.
03-18-2012 09:47 AM
Sure. You should bind the MGCP, SCCP, and other processes to a loopback interface on the router. Then you can choose to build your redundancy at layer two or three:
In either scenario you need to tell the core switches about the loopback interface. You could create a static route or extend your dynamic routing protocol of choice to the routers and advertise it.
Please rate helpful replies.
03-18-2012 09:47 AM
