cisco gateway telnet command help
David Hunt
When our phone system was installed over a year ago the tech that was onsite used a command when after he would telnet into our voce gateway that would display informatin about every call that was going through the system.
For the life of me I can not recall the command that he used.
It was like a debugging tool that everytime a call was placed information about the call, source, destination, protocolots, off hook, on hook, etc...
Can anyone please help jog my brain into remembering this cisco gateway command?
thanks in advance
yahsiel2004
Level 7
Level 7
show voice call status
debug isdn q931 ----->(Don't forget to turn on "term mon")
Yosh
HTH Regards, Yosh
yahsiel2004
Level 7
Level 7
Yosh
HTH Regards, Yosh
yes, that is the command, thank you!
You're welcome.
Yosh
HTH Regards, Yosh
