Cisco IAD 2431 SIP Trunking help needed.
SBjohnk
I'm trying to get a old IAD trunked to my PBX to enable some skinny phones to call out.
I've got registration working to the PBX but not calling.
I can call between my two phones (extensions 100& 101) just fine but when I try to call the PSTN I get a fast busy.
I've tried debugging ccsip messages when I place a call and do not see any output.
I'm lost here, I'm the PBX guy not the cisco guy (we don't have one of those).
Config below:
Test2431-16FXS#show run
Building configuration...
Current configuration : 5086 bytes
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname Test2431-16FXS
boot-start-marker
boot-end-marker
card type t1 1
logging message-counter syslog
logging buffered 4096
no aaa new-model
clock timezone MST -7
clock summer-time MDT recurring
network-clock-participate T1 1/0
network-clock-select 1 T1 1/0
ip source-route
ip cef
ip dhcp pool PHONES
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
option 150 ip 192.168.100.1
no ipv6 cef
voice hunt user-busy
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw redundancy
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
no call service stop
voice-card 0
archive
log config
hidekeys
controller T1 1/0
channel-group 0 timeslots 1-24
interface Loopback0
no ip address
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
interface Serial1/0:0
no ip address
no ip http server
no ip http secure-server
ip forward-protocol nd
logging source-interface Loopback0
tftp-server flash:apps45.9-4-2ES26.sbn
tftp-server flash:cnu45.9-4-2ES26.sbn
tftp-server flash:cvm45sccp.9-4-2ES26.sbn
tftp-server flash:dsp45.9-4-2ES26.sbn
tftp-server flash:jar45sccp.9-4-2ES26.sbn
tftp-server flash:SCCP45.9-4-2SR3-1S.loads
tftp-server flash:term65.default.loads
tftp-server flash:B016-1-0-4-2.SBN
control-plane
voice-port 2/0
no supervisory disconnect lcfo
no battery-reversal
voice-port 2/1
no battery-reversal
voice-port 2/2
no battery-reversal
voice-port 2/3
no battery-reversal
voice-port 2/4
no battery-reversal
voice-port 2/5
no battery-reversal
voice-port 2/6
no battery-reversal
voice-port 2/7
no battery-reversal
voice-port 2/8
no battery-reversal
voice-port 2/9
no battery-reversal
voice-port 2/10
no battery-reversal
voice-port 2/11
no battery-reversal
voice-port 2/12
no battery-reversal
voice-port 2/13
no battery-reversal
voice-port 2/14
no battery-reversal
voice-port 2/15
no battery-reversal
dial-peer voice 1 voip
description 10 Digit Dial
destination-pattern ..........T
session protocol sipv2
session target dns:f0fcdf.net
codec g711ulaw
dial-peer voice 30 voip
description 11 Digit Dial
destination-pattern ...........
session target sip-server
codec g711ulaw
dial-peer voice 100 voip
description Catch All Dial
destination-pattern .T
codec g711ulaw
sip-ua
credentials username user_XXXX password 7 XXXXXXX realm f0fcdf.net
keepalive target dns:f0fcdf.net
authentication username user_XXXXXX password 7 xxxxxxxx
registrar dns:f0fcdf.net expires 3600
sip-server dns:f0fcdf.net
telephony-service
max-ephones 10
max-dn 30
ip source-address 192.168.100.1 port 2000
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 4
system message CedarNetworks
cnf-file perphone
load 7916-24 B016-1-0-4-2
load 7965 SCCP45.9-4-2SR3-1S.loads
time-zone 6
max-conferences 8 gain -6
call-forward pattern .T
moh flash:music-on-hold.au
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Apr 04 2022 12:38:28
ephone-dn 10
number 100
label x100
ephone-dn 11
number 101
ephone 1
device-security-mode none
mac-address C025.5C43.0CDD
type 7965
button 1:10
ephone 2
mac-address 2893.FE13.4C0A
type 7965
button 1:11
line con 0
line aux 0
line vty 0 4
login
end
You can do that with this.
voice translation-rule 101
 rule 1 /\(....\)$/ /\1/
This rule will keep the last four digits and carry that over to the replace side where it is referenced with the \1 “command”.
For more information on voice translation rule please see this document.
Response Signature
SBjohnk
Update, I deleted the dial-peers except for peer 1 and I can now call out.
How can I route my incoming DID's to the phones?
SBjohnk
OK, so with a translation rule I have incoming calls to 5202764508 and to 5203857734.
 rule 1 /5202764508/ /101/
 rule 2 /5203857734/ /100/
voice translation-profile INCOMING
 translate called 101
 Is there a better way to do this? I'd like to get a range of DID's and rewrite to the last 4 digits.
Response Signature
