Cisco IM&P Sync Agent issues
Kane Smith
Hi all,
I have CUCM 11.5 and an IM&P 11.5 in my lab environment, both are in the same LAN and DNS is working fine. I have two error messages when I run the system troubleshooter - Cisco Sync agent and SIP Publish model. Screenshot attached. The Cisco Sync service is running. I have tried restarting it and even rebooted both VMs. The issue I am facing is that if I make any changes to the UC services, these don't get propagated to IM&P and hence Jabber still sees the old details, i.e. old CUC IP address etc. Any ideas please?
Problem solved! It was this bug:
CUPS Cisco Sync Agent stops after upgrade to 11.5.1.12900-25
CSCvd02541
Description
Symptom:
Sync Agent stops running on IM and Presence Server.
Conditions:
Upgrade IM&P from 11.5.1 SU1 to 11.5.1 SU2 while CUCM is still on 11.5.1 SU1.This condition is applicable only to version 11.5.1.
Workaround:
Please make sure CUPS and CUCM both are on 11.5.1 SU2
I upgraded CUCM to SU3. No errors at all now.
Hi Kane,
did you check that the port specified on SIP trunk confgigured on CUCM matches the application listener port on IM&P?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi, thanks for your reply.
Yes, I checked and it is the default of 5060. I rebooted the server and noticed that the services take a very long time to start up. Eventually all services start except the Sync agent. I need to start this manually. Then after a while I ran the System Troubleshooter and I see that the Sync agent has stopped again and I also have the SIP Publish Model error.
CSCvd02541
Description
Symptom:
Conditions:
Workaround:
Great Job Kane!
