Cisco IP Communicator aurto startup
HowYee
Can CIPC auto start up when I turn on my PC?
HowYee
2 Accepted Solutions
ronpatel
Level 8
Level 8
Hi HowYee
We have bug raised for it. It may come in future release.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsc56951
As a workaround
For auto-start, copy the Cisco IP Communicator shortcut icon from the desktop into the "Startup" folder.
Ronak patel
Rate helpful posts by clicking starts below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Aaron Harrison
Of course. Just add a shortcut to the .exe in the 'Startup' programs group in the Start Menu on your PC.
Or if you want a way that is not visible to the users or can be easily automated, add it to the 'Run' registry key:
http://support.microsoft.com/kb/314866
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
ronpatel
Level 8
Level 8
Hi HowYee
As a workaround
Ronak patel
Aaron Harrison
Aaron Harrison
Hi Aaron & Ronak,
Thank you so much...
HowYee
You're welcome!
