Cisco ip communicator for win 11 on Mac M1
tobiash1
Is it or will it be possible to run Cisco ip communicator on a Mac M1 using Parallels/Win 11
Jaime Valencia
No way to answer that, you'll have to test it out to find out if it will work or not, the product is EOL/EOS and anything EOS is no longer tested for compatibility.
https://www.cisco.com/c/en/us/support/collaboration-endpoints/ip-communicator/series.html
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_6/Release_Notes.html#CIPC_RF_A5233D61_00
I'd suggest you look at Jabber instead.
java
if this helps, please rate
Jaime Valencia
java
It does not work this I do know. Thank you for the answer it explains a lot very helpful.
