How to update directory number information in bulk
sevenega
Is there is a way to update / modify in bulk the Description, Alerting Name and ASCII Alerting Name of many directory numbers?
Jaime Valencia
Yes, you need to use BAT, do a quick search at the forum and you'll find plenty of threads on the topic and even an event (think it was an ask the expert or something along those lines) specific to how to use BAT, if you google Cisco BAT it's very likely you'll even find videos on how to use it.
java
if this helps, please rate
As JAVA mentioned You can do that with BAT. Here is the link from Cisco community for a similar thread. If you search,  you will find a lot  other threads related to same question.
https://community.cisco.com/t5/ip-telephony-and-phones/bulk-edit-line-display-ascii-display-and-line-text-label/td-p/2959806
Response Signature
