10-30-2013 03:05 AM - edited 03-16-2019 08:08 PM
As per the vulnerability report (Qualys Guard), we are seeing couple of vulnerabilities wrt 7940 IP Phones.
The report says...
OS:
Linux 2.4-2.6 / Embedded Device / F5 Networks Big-IP
Issue:
Web Server/ Web Application Vulnerable to Cross-Site Scripting Attacks
Threat:
Your Web server/application does not filter script embedding from links displayed on a server's Web site.
Pls suggest what action needs to be take to resolve this issue.
Solved! Go to Solution.
10-30-2013 06:29 AM
Because the phone is not really a web site and does not supports scripting at all.
You can also disable web access and that's it.
10-30-2013 03:42 AM
False alarm, no action needed.
10-30-2013 04:13 AM
Thanks for the update.
Any additional inputs how it could be a false alarm.
Jagadish G
10-30-2013 06:29 AM
