11-25-2013 05:03 AM - edited 03-16-2019 08:34 PM
One of my ip phone activate the speaker phone by itself. I can place call and receive but when I am not using the phone after a while the speaker button green up and you hear the dial tone. I reset the phone many times and factory reset it. Any idea how to fix this?
11-25-2013 07:57 AM
I would suggest a packet capture to see who initiates the off-hook event. It's possible that a CTI event or XML SDK command triggered it and a packet capture would show this. If the phone is sending the off-hook to CUCM without any triggering event then it's a hardware failure.
Please remember to rate helpful responses and identify helpful or correct answers.
11-25-2013 12:55 PM
Is this happening to one phone or all the phones?
Could be the mechanical spring at the base of the button is already worn off.
