IP Telephony and Phones
watch here Journey banner_1
Labels
I am trying to assist my uncle with setup of a PRI on their CME router.  I've created the pri-group and I can see the channels are good and the call comes in, but always end in fast busy.  I do not see the voice-port populating after created the pri-...
Jaswild999 by Level 1
  • 2757 Views
  • 10 replies
                   Hello Cisco TeamI am planning to install 20 ip phones 7942 and 5 ip Communicators but I got some doubts in licensing,FirstWhat is the difference between FL-CME-SRST-25 and SW-CCME-UL-7942, do I have to buy both?Can I take 5 license...
Hello, if the command 'mls qos trust xxxxx' is not issued, and qos is turned on for the interface, does this mean the switch will erase all cos and dscp markings received, therefore preventing me from testing packets/frames against these cos/dscp val...
fran19422 by Level 1
  • 982 Views
  • 3 replies
hi,got this config,voice translation-rule 1000 rule 1 /^9/ //voice translation-profile STRIP_9 translate called 1000dial-peer voice 30 pots translation-profile outgoing STRIP_9 destination-pattern 95554443333 port 0/0/0 forward-digits all!voice-port ...
Hi to you all,I am having strange problem with one single 6941 IP phone not hearing ringack when making calls. This is for internal and external calls. The rest of the phones at site are fine but when this one makes calls, they don't hear any ringbac...
Ess Emque by Level 1
  • 361 Views
  • 1 replies
All,I am having an issue with a hunt list.  There were no problems reported on CM 7.1 but after an upgrade to CM 9.1 users are complaining about getting a quick double-ring when no one from the hunt list answers and the call is getting routed to voic...
