12-03-2014 01:00 AM - edited 03-17-2019 01:10 AM
hello,
I would like to have information on a Cisco 7942 phone.
The green lamp (speaker) will continue to remain lit and the phone no longer works.
Is it possible to repair the phone ?
Thank you for help.
Valentin.
12-03-2014 02:37 AM
Try a factory reset as per the following:
Step 1 Unplug the power cable from the phone and then plug it back in.
The phone begins its power up cycle.
Step 2 While the phone is powering up, and before the Speaker button flashes on and off,
press and hold #.
Continue to hold # until each line button flashes on and off in sequence in amber.
Step 3 Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Let us know if it works.
Manish
12-03-2014 03:01 AM
Thank you for reponse but does not work...
The green lamp will continue to remain lit. The window is white, nothing is visible (picture attached).
12-03-2014 03:41 AM
Looks like the phone needs to be replaced if the factory reset has also not helped.
Manish
12-03-2014 04:07 AM
So, the terminal is dead ?
Valentin
12-03-2014 07:49 AM
Hi ValentinNICOLLE,
do you have a smart contract or advanced RMA license with your phone unit? you may be able to replace the phone if you have these. for further questions please feel free to send me a message at fguasque@cisco.com
hope this helps!
12-04-2014 12:05 AM
The guarantee was abolished on 2011 .. I cannot replace the phone.
I would like know if it's possible to repair this phone or not.
If isn't possible i buy a new material.
12-03-2014 03:46 AM
There is a chance for the device to be firmware corrupted as well.
1. CUCM version
2.Default firmware version of the phone and the current firmware of the phone.
Afsal Abdul Gafoor
12-03-2014 04:05 AM
I don't think that the problem is a firmware version.
The issue started as a result of a power failure.
Sorry for my english but i'm french and i speak little bit english.
Nicolle Valentin
01-15-2015 11:19 AM
Hello, ValentineNICOLLE.
Since the warranty of your Cisco 7942 phone already expired and irreplaceable, i would suggest that you try to avail the Cisco Trade In Program. If you want further assistance, email me directly at (bsiapco@cisco.com)
Thanks!
Barry
