05-27-2012 09:41 AM - edited 03-16-2019 11:22 AM
Is Cisco IP Phone 9601 supported on CUCME 8.6 ?
How can I configure it on CUCME8.6 ?
05-27-2012 09:42 AM
Sorry I mean 6901
05-27-2012 09:59 AM
Hi Ievalley,
Please use the below links,
Hope it helps.
Anand
Pls rate helpful posts !!
05-27-2012 11:36 AM
The links don't work
05-27-2012 01:39 PM
If you do not have partner level access, simply remove the partner word from the links provided.
Chris
05-27-2012 03:45 PM
You can check this link, you don't need partner access level:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet_c78-678145.html
It contains all supported IP Phones. The 6901 is supported.
Regards.
