Cisco IP Phone 9601
ievalleyccie
Is Cisco IP Phone 9601 supported on CUCME 8.6 ?
How can I configure it on CUCME8.6 ?
5 Replies 5
ievalleyccie
Sorry I mean 6901
The links don't work
If you do not have partner level access, simply remove the partner word from the links provided.
Chris
Emmanuel Valdez
Level 3
Level 3
You can check this link, you don't need partner access level:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet_c78-678145.html
It contains all supported IP Phones. The 6901 is supported.
Regards.
