05-15-2021 06:33 PM
I have been using a Cisco ASA 5505 for 10 years with a Cisco phone running any connect SSL VPN client. I switched to a Fortinet Firewall l and once a day the SSL VPN drops and the phone is no longer registered and I have to reconnect manually.
Has anyone else seen this?
05-31-2021 02:49 AM
My guess is this is triggered by the key-rollover that occurs periodically, often this timer is set once every day
and this key-rollover may have happened more fluent with the ASA then using the Fortinet
06-13-2021 11:47 AM
What do you mean by more fluent?
06-13-2021 11:13 PM
without interruption
