07-15-2015 04:19 AM - 편집 03-18-2019 11:35 AM
Cisco Ip phone -->CUCM--(MGCP)--3945 Gateway/ E1 -->Service Provider. When we make an outbound calls from Cisco phones, calls getting connected properly but when the called party disconnects the calls, we see the calls disconnect but Call timer is still active on Cisco phones and hear fast busy tone. We use MGCP. Any suggestions? Debug ISDN q931 shows disconnect received immediately after the called party ends the call.
날짜: 07-15-2015 07:07 AM
Please try adding: voice call disc-pi-off
edit: In global config if that wasn't clear
날짜: 07-17-2015 04:20 AM
Will.alvord
I tried voice call disc-pi-off. It doesn't work.
날짜: 07-20-2015 01:31 PM
Sorry about that. I read 'mgcp' but thought 'h.323'. It might be timer-related like someone else suggested, but doesn't sound like it to me. Unfortunately, I don't get to work with many E1 configs, but possibly the 'Convert Progress to Disconnect for User Side PRI EURO' call manager service parameter?
날짜: 07-15-2015 09:51 AM
Can you paste the output of command "sh isdn timer"
날짜: 07-15-2015 11:29 AM
can you share debug MGCP packets? we need to see what is happening when you receive ISDN disconnect IE.
날짜: 07-17-2015 04:25 AM
mohammed al baqari
Service provider says, this is their standard settings and we need to fix it on gateway side. We receive alerting when we end the calls.
Jul 15 18:12:42: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8020
Jul 15 18:12:43: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8020
Jul 15 18:12:50: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8020
Jul 15 18:12:50: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0020
Jul 15 18:13:13: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8020 à I pressed end call on mobile and again I receive Alerting message rather than Disconnect
Jul 15 18:13:13: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8 callref = 0x0020
Jul 15 18:13:13: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8020
Jul 15 18:13:14: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0020
Jul 15 18:13:14: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8020
날짜: 07-17-2015 04:23 AM
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 Timers (dsl 0) Switchtype = primary-net5
ISDN Layer 2 values
K = 7 outstanding I-frames
N200 = 3 max number of retransmits
T200 = 1.000 seconds
T202 = 2.000 seconds
T203 = 10.000 seconds
ISDN Layer 3 values
T301 = 180.000 seconds
T303 = 4.000 seconds
T304 = 30.000 seconds
T305 = 30.000 seconds
T306 = 30.000 seconds
T307 = 180.000 seconds
T308 = 4.000 seconds
T309 Disabled
T310 = 40.000 seconds
T313 = 4.000 seconds
T316 = 120.000 seconds
T318 = 4.000 seconds
T319 = 4.000 seconds
T322 = 4.000 seconds
T3OOS = 5.000 seconds
TGUARD= 8.000 seconds, Expiry = REJECT_CALL
T-activate = 4.000 seconds
*** dsl 1 is not configured
*** dsl 2 is not configured
*** dsl 3 is not configured
*** dsl 4 is not configured
*** dsl 5 is not configured
*** dsl 6 is not configured
*** dsl 7 is not configured
*** dsl 8 is not configured
*** dsl 9 is not configured
*** dsl 10 is not configured
*** dsl 11 is not configured
*** dsl 12 is not configured
*** dsl 13 is not configured
*** dsl 14 is not configured
*** dsl 15 is not configured
*** dsl 16 is not configured
*** dsl 17 is not configured
*** dsl 18 is not configured
*** dsl 19 is not configured
*** dsl 20 is not configured
*** dsl 21 is not configured
*** dsl 22 is not configured
*** dsl 23 is not configured
*** dsl 24 is not configured
*** dsl 25 is not configured
*** dsl 26 is not configured
*** dsl 27 is not configured
*** dsl 28 is not configured
*** dsl 29 is not configured
*** dsl 30 is not configured
*** dsl 31 is not configured
*** dsl 32 is not configured
*** dsl 33 is not configured
*** dsl 34 is not configured
*** dsl 35 is not configured
*** dsl 36 is not configured
*** dsl 37 is not configured
*** dsl 38 is not configured
*** dsl 39 is not configured
*** dsl 40 is not configured
*** dsl 41 is not configured
*** dsl 42 is not configured
*** dsl 43 is not configured
*** dsl 44 is not configured
*** dsl 45 is not configured
*** dsl 46 is not configured
*** dsl 47 is not configured
*** dsl 48 is not configured
*** dsl 49 is not configured
*** dsl 50 is not configured
*** dsl 51 is not configured
*** dsl 52 is not configured
*** dsl 53 is not configured
*** dsl 54 is not configured
*** dsl 55 is not configured
*** dsl 56 is not configured
*** dsl 57 is not configured
*** dsl 58 is not configured
*** dsl 59 is not configured
*** dsl 60 is not configured
*** dsl 61 is not configured
*** dsl 62 is not configured
*** dsl 63 is not configured
*** dsl 64 is not configured
*** dsl 65 is not configured
*** dsl 66 is not configured
*** dsl 67 is not configured
*** dsl 68 is not configured
*** dsl 69 is not configured
*** dsl 70 is not configured
*** dsl 71 is not configured
*** dsl 72 is not configured
*** dsl 73 is not configured
*** dsl 74 is not configured
*** dsl 75 is not configured
*** dsl 76 is not configured
*** dsl 77 is not configured
*** dsl 78 is not configured
*** dsl 79 is not configured
*** dsl 80 is not configured
*** dsl 81 is not configured
*** dsl 82 is not configured
*** dsl 83 is not configured
*** dsl 84 is not configured
*** dsl 85 is not configured
*** dsl 86 is not configured
*** dsl 87 is not configured
*** dsl 88 is not configured
*** dsl 89 is not configured
*** dsl 90 is not configured
*** dsl 91 is not configured
*** dsl 92 is not configured
*** dsl 93 is not configured
*** dsl 94 is not configured
*** dsl 95 is not configured
날짜: 07-17-2015 02:14 PM
Could you please run "debug isdn q931" and paste logs for 1 call...need to check all the events and may need to check the isdn timer settings.
날짜: 07-17-2015 01:06 PM
Basically you have to See the Disconnect Cause code what is received. CUCM will play the re order tone for Cause code like “82 D6”. You may modify the T305 in CUCM if need to adjust the re order tone duration. So it is worth checking the cause code sends by provider and reason for the same if it causes the re order tone.
Best Regards,
Jebin
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
