Cisco IP Phone Connectivity
Bhavani Sankar
Hi All,
Can we connect an IP phone in the access port of another IP phone, instead of PC?
Sankar.
Terry Cheema
Yes it works, i had done once for the sake of trying. What are you planning to do?
-Terry
Hi Terry,
We are planning  to connect as we are short of I/O ports in the cubicle.We will try it and update you.
Thank you very much.
Sankar.
It will work, assuming power cube, but this is not supported nor recommended.
No worries, let me know how it goes.
-Terry
