cisco ip phone headset
shimjidpc
can we use any headset brands for cisco ip phone? If not, please advice me some affordable headset brands.
5 Replies 5
Stoyan Stoitsev
Level 8
Level 8
You can try Plantronics
http://www.plantronics.com/ciscouc/index.jhtml
or Jabra
http://www.jabra.com
BR,
Stoyan
so it wont work with headset brands which are not recommended by cisco?
It's just that the pinout of the Cisco headset port on the phone is a bit different so you need a special cable.
Of course you can always DIY ;) Here's a sample:
http://www.mml.uni-hannover.de/einhorn/headset/index_e.html
BR,
Stoyan
You can also use Acoustical innovations
www.aiheadsets.com/Cisco-Headset.html
There are a few products that allow using PC or cell phone headsets with some Cisco phones. For example:
http://www.headsetadapter.com/cisco-phones.html
http://amzn.to/1scongt
http://amzn.to/1WPBYqj
