cisco ip phone pickup without ring
whanson
Level 2
Level 2
Is there a way to define an extension so that it when it is dialed the called party can visually see that someone is calling and pickup without the phone ringing?
alessandro.dona
Level 3
Level 3
If you are using 7940 you can use flash only option on a second line!
Rob Huffman
Hi Bill,
Just thought I would add a little to Alessandro's good info;
Device>Phone>Directory Number Configuration
Directory Number Configuration Settings
Ring Setting (Phone Idle)
Use this field to configure the ring setting for the line appearance when an incoming call is received and no other active calls exist on that device. Choose one of the following options:
Use system default
Disable
**Flash only**
Ring once
Ring
From this 4.1.3 doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed74c.html#wp1245287
Hope this helps!
Rob
