Cisco IP phones able to register without voice VLAN declared
Jason Lachowsky
Level 4
Level 4
I am used to declaring a PC/phone switchport combination such as:
 switchport access vlan 1050
 switchport mode access
 switchport voice vlan 2005
 trust device cisco-phone
 auto qos voip cisco-phone
 spanning-tree portfast
 service-policy input AutoQos-4.0-CiscoPhone-Input-Policy
 service-policy output AutoQos-4.0-Output-Policy
This registers phones correctly on the Voice subnet I've defined and also assigns the correct subnet to the PC.
Printers are declared like:
 switchport access vlan 1101
Phones connected to these switchports are also able to connect successfully to CUCM but will receive an IP address in the wrong subnet.
Any thoughts on why this is happening?
Unfortunately, we're using Novell to issue DHCP addresses.
Thanks much.
2 Accepted Solutions
Deven Gandhi
Most llikely, you have option 150 setup on data DHCP scope so when these phones send out DHCP request, it is grabbing IP from data subnet and registering with call manager with data subnet vs voice subnet.
-Deven Gandhi
*Please rate all useful post
Mark Malone
Hi Thats what i would expect to happen the phone will receive an ip address whether vlan is correct or not thats what will happen in most standard setups the question is why are you plugging phones into a data vlan thats not set for voice ,Its nothing to be concerned about either dhcp server has no concept of command voice vlan
Deven Gandhi
-Deven Gandhi
Both Deven and Mark are correct here. The Novell DHCP server administrator probably defined the Option 150 that tells a phone how to reach CUCM at a global level instead of only within the scopes that cover the voice subnets. They can certainly change that if they feel like it; even Microsoft supports it and any modern Novell install is running on SUSE which probably leverages dhcpd like any other GNU/Linux system on the planet.
Additionally, in the absence of DHCP 150, 66, or the rarely known about default DNS query a phone will default back to the last config it had in memory and use the servers defined there. In other words, even if the DHCP server isn't handing out a DHCP Option 150 at all, the phone will still register if it has ever done so before.
Lastly, as Mark was saying, the voice VLAN was only invented to prevent companies from having to redesign their entire network subnetting, including every statically assigned device, to deploy IP phones. Think about it for a moment: your /24 DHCP scope is 70% exhausted and you need to deploy 150 phones within that same network segment. Without a voice VLAN you would be forced to change the subnet for the entire network segment. It was a essentially a way to remove objections to VoIP originally; however, other decisions got made after that invention including that lazy brat AutoQoS. It bases the conditional trust model for physical phones off of the presence of an 802.1p CoS header which can only exist because of the Voice VLAN concept which introduces an 802.1q header.
Great points. Thanks, Jonathan.
Mark Malone
