Cisco ISR4331 with GrandStream UCM6304A connection
Mo7eid
I need your support to configure SIP trunking communication between Cisco ISR 4331 with GS UCM6304A.
SIP trunk is configured in the UCM6304A, but I can't do it for the Cisco SR.
attached is the Cisco 4331 license.
can you guide me with the steps.
Appreciated
WE normally do that using CLI. You need to create Dial-peers pointing to the Grand stream.
Refer the below guide.
https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
Response Signature
