Cisco Jabber 12.6 VM ICON
GERARDO GALVAN
I'm trying to deploy Jabber 12.6 but I just notice that there is not VM icon, is there a way to fix this issue?
Jaime Valencia
Are you using full UC mode or soft phone? Or IM only?
Have you configured the VM profile?
java
if this helps, please rate
George Sotiropoulos
Dear Gerardo,
Can you please provide more information regarding your implementation? Do you have a CUCM (which version?). Moreover, if you have a CUCM please can you check the UC Service Configuration and maybe download the jabber-config.xml to share it with us?
Kind regards,
George
Hope the above helps,
gsotirop
