09-28-2012 11:15 AM - edited 03-16-2019 01:26 PM
I'm using a UCM 8.5(1) with COP for Jabber for iPhone and iPad, but it refuses my connection and it aky for a password.
Where should I configure that password?
How do I login on to my chisco Jabber?
Solved! Go to Solution.
09-28-2012 11:53 AM
You need to login with your CUCM end user account.
This should be associated with your iPad device.
Sent from Cisco Technical Support Android App
09-28-2012 12:40 PM
Hello Pedro,
Like mmoulson1 said you need to use the end user and password that is associted with your device in CUCM.
Leonardo Santana
Rate this if helps!
09-28-2012 11:53 AM
09-28-2012 11:54 AM
Hello Pedro,
Take a look on the Jabber for IPAD Admin Guide!
https://supportforums.cisco.com/docs/DOC-23292
You are using Webex or Presence? You are using LDAP Integration?
Leonardo Santana
09-28-2012 12:33 PM
Hi Leonardo,
I'm not using LDAP.
And on Jabber, it show's a error mesage "invalid username or password"
What is that Password?
09-28-2012 12:40 PM
Hello Pedro,
Leonardo Santana
Rate this if helps!
