Cisco Jabber Phone Mode Only with Windows 7 and 8
cl1325
Cisco Jabber for Windows in Phone Mode only...
Need to know if this is supported on version CUCM 8.6 ?
We do not want to use or integrate CUPS or Cisco Presence.
This is a premis based cluster owned and hosted at the customer site.
Looked all over the website and cannot find the answer.
Can a link be provided so I can show my client... I told them this is not possible and they are getting mixed info from others and I can't prove this right or wrong.
Help!
It is
Please advice
https://supportforums.cisco.com/docs/DOC-23292
Please Kudos/rate if this help!
Not sure how the link is related to Jabber as Phone, and I am unsure of official support as last time I checked it was still under beta (use at your own risk) but it does work. In fact I have it working fine with CUCM 8.5.
HTH,
Chris
Thanks Jose- this seems to relate to Iphone, I'm not looking to use Iphone, only Jabber client on workstations in Phone-Mode Only with CUCM version 8.6, not using Presence or CUPS server.
Thanks Chris- I still need something in writing from Cisco documents showing support or non support. Apperciate your time and response as now I know it can possibly work with 8.6
If you are a partner you should open a case with PDI helpdesk, if you are a customer contact TAC for confirmation.
HTH, please rate all useful posts!
Chris
