10-10-2013 04:57 AM - edited 03-16-2019 07:49 PM
The softphone is not working for cisco jabber windows
Attached is the logs
CUCM AND CUPS version 9.x
I found the below but is not clear to me what is the issue
2013-10-10 12:53:42,577 DEBUG [0x00001360] [tionplugin\StatusBarPhoneButton.cpp(127)] [plugin-runtime] [OnCanSelectDeskphone] - enabling deskphone menu items
2013-10-10 12:53:42,577 DEBUG [0x000011a8] [src\config\TftpHelper.cpp(114)] [csf.ecc] [ecc::TftpHelper::doRetrieveFile] - Received error: eFileNotFound downloading file using HTTP from 'http://10.255.0.11:6970/CTLSEPCSFKIKACHRISTOU.tlv', not trying TFTP following an explicit HTTP "not found" error.
10-17-2013 05:46 AM
Chrys,
Can you run this command and attach the config file here..x.x.x.x=ip address of your tftp server
tftp -i x.x.x.x get CSFKIKACHRISTOU.cnf.xml
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
10-17-2013 05:57 AM
Aok
Attached is the file
I dint see any usuful there
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
10-17-2013 06:02 AM
Nothing attached
10-17-2013 06:03 AM
check above
with the others attached
Chrysostomos
10-19-2013 05:35 AM
Aok
Did you find anyhting?
Chrysostomos
10-17-2013 11:46 AM
Hi guys. I've also had a similar problem. In my case CSFs can get registered, but can't failover in case of CUCM going down.
05-03-2018 08:50 AM
My softphone stopped working. I ended up resetting Jabber then the softphone started working again.
