IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5956 Views
  • 14 replies
We have a few servers that have an IVR application that connects to a voice gateway via CAS T1s. I'm in the process of retiring a 2811 gateway and this is being moved over to our 4451. We are running CUCM 10.5 and the T1 is registered via MGCP. I've ...
Hi, Not sure if this is at all possible, but... - Does CUBE HA / HSRP support the use of Layer 3 port channel on the CUBE router end?We are looking to make use of Nexus vPC capability by doing CUBE Layer 3 Portchannel > Nexus 7k Layer 2 vPC in access...
robwu2006 by Level 1
  • 3357 Views
  • 15 replies
We've got an issue whereby CUBE is terminating calls after 30 minutes. At first glance, this is understandable: The default session timer is 30 minutes in CUBE. But as part of the call setup, the ITSP is sending a "Min-SE: 600" header - which surely ...
I'm very new to VoIP so go easy on me.   Here is our current dial-peer configuration. We are looking to just have any call from our SIP provider to be passed directly to CUCM. We are an organization with a lot of numbers all over several states. Main...
campbech1 by Level 1
  • 800 Views
  • 5 replies
Cisco SBC [ASR 1006] I was wondering, whether it is possible to use DNS entry instead of static IPs under remote-address and signaling-peer. We have one partner using DNS instead of IP since the peer IP is frequently changing.   Please advise.   Than...
Netmart by Level 1
  • 382 Views
  • 3 replies
Just received my first two 8832's.  GUESS WHAT?!?! There's not a **bleep** thing inside that box that powers that bad boy up.  NOPE, you gotta spit out some more money if you want this piece of **bleep** to do ANYTHING!  So, I just paid $1800.00 for ...
We are looking to add Extension Mobility as a feature available to our users. We are currently on version 10.5.2(SUx) for both Cisco Unity Connection and Cisco Communications Manager. We share a Cisco Unity Connection cluster/pair with 2 CUCM Leaf Cl...
Call forward is not working when any body try to call from outside and from internal it's working. Call Flow: outside caller >>Telco>>Voice gateway(E1)>>CUCM>>8851 IP phone>> forwarded to mobile>>Voice gateway>>Telco.   Calling:056XXXXXXXX Orginal Ca...
