Cisco Message " Call cannot be completed as dialled" before forwarding calls
Kaushik Ray
Hello I have a setup where the two ends of link are routers conencted to PABX
Trunk dialling is required but when then call there is a message "Call Cannot be completed" before the call is actually forwarded and established fine.
Any advise as to how this can be overcome? Let me know if any other relevant information is needed.
the configuration on the E1s are as follows:
A end
controller E1 0/0/1
 framing NO-CRC4
 pri-group timeslots 1-31
 description ### PABX MITEL ###
interface Serial0/0/1:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-qsig
 isdn overlap-receiving T302 2000
 isdn incoming-voice voice
 isdn send-alerting
 isdn bchan-number-order ascending
 no cdp enable
voice-port 0/0/1:15
 cptone GB
 timeouts interdigit 5
 bearer-cap Speech
B end
controller E1 0/0/0
 framing NO-CRC4
voice-port 0/0/0:15
 cptone GB
 bearer-cap Speech
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn send-alerting
 no cdp enable
23 Replies 23
Hello Kaushik,
I have gone through debug output, and problem is due to some misconfiguration in dial-peers.
So call is routed in two attempts.
- First gateway routes the call using first digit, so there has been no dial-peers for that, so that's why you get that announcement first.
Incoming Dial-peer=4000
Called Number=8(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Failure observed:
*Jun 15 14:39:49.791: //179/2CFC01BE8037/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x271EB1C, Call Id=179
- After failure to route call with one dial-peer, as per default hunting mechanism it tries to send the call again , with another dial-peer.
Called Number=8268(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3001, Call Count On=FALSE,
*Jun 15 14:39:49.803: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
This time call connects. So problem seems to be happened due to these two dial-peers.
dial-peer voice 1000 voip
 translation-profile outgoing profile1
 preference 2
 destination-pattern .
 progress_ind setup enable 3
 session target ipv4:
 dtmf-relay h245-alphanumeric
 playout-delay nominal 130
 playout-delay mode fixed
 fax-relay ecm disable
 fax rate 9600
 fax nsf 000000
 ip qos dscp cs5 media
 ip qos dscp cs5 signaling
 clid network-number 441224374190
 no vad
dial-peer voice 1001 voip
 preference 1
 fax rate 9600
 fax nsf 000000
 no vad
As they can route the call using only one digits, which is for sure , will be rejected by  other end, so you get that announcement.
So to fix this problem, either you can shut these dial-peer if they are not in use, or you can modify the destination-patter, so that it will not match with any random digit.
so destination pattern should look like this:
destination-pattern .T or destination-pattern ....T
Also direct-inward-dial command is not intended for outgoing dial-peers , so you can remove it from POTS dial-peer which are for outgoing.
Amit
Thanks a lot for your thoughts Amit
I will amend the dial-peer destination pattern and test once more.
But the 1000 and 1001 voip have been configured and session targets been configured for the E1 0/0/0 on Router A; could it potentially cause issues with the other one as well?
Hello Kaushik,
Ideally it should not have an impact, as these are outgoing dial-peers , which should be pointing towards Router B, to send the calls. So we just want to force these dial-peer not to send the call with just 1 digit, so appending T in destination pattern, will cause it to wait unless interdigit timeout is expired.
\ Amit
Thanks I will amend the dial-peers and test.
just for a bit of more information the dial-peer 1000 and 1001 does not point to the Router B but points to a CUCM.
Essentially the phones through the E1 0/0/0 and E1 0/0/1 are separate voice lines to act as a backup if one or the other is not working.
Thanks changing dial peers 1000 and 1001 to .T fixed it!! thanks a lot for your help,
Amit Kumar
Hello Kaushik,
It seems that router is sending the call to other end , say CUCM even before complete digits are received. It would be great if you can share complete configuration , so that we can have a look in to dial-peer as well.
There could be two remedies , which can be used here:
1 - Configure Mitel PABX not to use Overlap sending, so that it can send all digits in Setup Message.
2. Incoming dial-peer matching with this call, should not have "incoming called-number . " command, as that will force router to send the call to another side, say CUCM, as soon as first digit is received. So call will be failed in that way.
Please do collect below said debugs for more details analysis:
debug isdn q931
debug voip ccapi inout
Amit Kumar
Thanks Amit Kumar for your reply.
dial-peer voice 4000 pots
 tone ringback alert-no-PI
 destination-pattern 1...
 direct-inward-dial
 port 0/0/1:15
 forward-digits all
Pots config and debug below
*Jun 15 11:44:04.155: %SYS-5-CONFIG_I: Configured from console by vty0 (172.20.45.51)
*Jun 15 11:44:22.099: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8  callref = 0x0047
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x91AA068001008201008B0100A11302017D06042B0C0900300880064578746E2031
        Calling Party Number i = 0x4980, '1201'
                Plan:Private, Type:Subscriber(local)
        Called Party Number i = 0x80, '8'
                Plan:Unknown, Type:Unknown
        High Layer Compat i = 0x9181
*Jun 15 11:44:22.099: ISDN Se0/0/1:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8047
*Jun 15 11:44:22.287: ISDN Se0/0/1:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0047
        Called Party Number i = 0x80, '2'
*Jun 15 11:44:22.539: ISDN Se0/0/1:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0047
        Called Party Number i = 0x80, '6'
*Jun 15 11:44:22.791: ISDN Se0/0/1:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0047
*Jun 15 11:44:24.043: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8047
*Jun 15 11:44:24.047: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8  callref = 0x8047
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Jun 15 11:44:32.731: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0047
        Cause i = 0x8090 - Normal call clearing
*Jun 15 11:44:32.731: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x8047
*Jun 15 11:44:32.743: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0047
A end
dial-peer voice 3000 voip
destination-pattern 9T
session target ipv4:10.49.54.1
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 3001 voip
destination-pattern [2-9]...
fax rate 9600
fax nsf 000000
no vad
B end
direct-inward-dial
port 0/0/1:15
forward-digits all
direct-inward-dial
port 0/0/0:15
forward-digits all
session target ipv4:172.26.70.241
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 4001 pots
direct-inward-dial
port 0/0/0:15
forward-digits all
Andre Castro
There could be an issue with calling privileges
Rgds,
Andre
