04-27-2013 03:23 AM - edited 03-16-2019 05:01 PM
Hello, who met this problem?
Cisco Mobile 8 IN call OK
Cisco Mobile 8 OUT call drop 20 seconds
04-27-2013 04:57 AM
Hi kairat,
Are Dropping call internal/external(pstn)? Could you attached the call traces?
Have you try running Cisco jabber? Are you running Cisco Any connect?
Sent from Cisco Technical Support Android App
04-27-2013 06:42 AM
Now it is not at work, I can not attach the logs.
on Monday.
Dropping any outgoing calls
10.10.8.X DHCP Voip
i Connect from 10.10.10.X (MANAGEMENT)
