Cisco Mobile 8 out call drop 20 seconds
AeO_DiT_cisco
Hello, who met this problem?
Cisco Mobile 8   IN  call  OK
Cisco Mobile 8  OUT call drop 20 seconds
Hi kairat,
Are Dropping call internal/external(pstn)? Could you attached the call traces?
Have you try running Cisco jabber? Are you running Cisco Any connect?
Sent from Cisco Technical Support Android App
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Now it is not at work, I can not attach the logs.
on Monday.
Dropping any outgoing calls
10.10.8.X DHCP Voip
i Connect from 10.10.10.X (MANAGEMENT)
