Cisco one way audio
I have one way audio from PSTN to IP Phone.
1. From IP phone to IP phone its working
2. From IP phone to pstn line i can hear (outbound working)
3. PSTN phone to IP phone i am not able to hear. No voice is coming from that side (in bound not working from pstn to call gateway)
Can some help.
Ayodeji Okanlawon
One way audio is always down to routing issue. Can your PSTN gateway ping the subnet of your ip phones?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
8 Replies 8
Ayodeji Okanlawon
yes that i can ping the subnet as its been handle by inter vlan routing..
card type e1 0 3
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
isdn switch-type primary-net5
voice-card 0
no dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface FastEthernet0/1
no ip address
no ip unreachables
ip nat inside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1.10
description SUB_INT_SUPPORT
encapsulation dot1Q 10
ip address X.X.150.1 255.255.255.0
ip flow ingress
ip nat inside
ip policy route-map AIRTEL_2
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/3/0:15
ccm-manager redundant-host X.X.150.8
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server X.X.150.7
ccm-manager config
mgcp
mgcp call-agent X.X.150.7 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1.10
mgcp bind media source-interface FastEthernet0/1.10
mgcp profile default
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions hardware 10
dial-peer voice 1 pots
service mgcpapp
port 0/3/0:15
Are you doing some form of NATing as I can see NAT configs on the gateway..
Abhishek Singh
Hi Nitesh,
Try pressing the question mark button on the phone and see the Tx and Rx messages that are flowing , and see whether there is a continous change in them. Also as mentioned above - please check if NAT scenario is there -- before you consider it to be specific TELCO issue.
Please rate helpful posts.
Whatever level you reach getting better never stops -- Sachin Tendulkar
NAT is there for going outside and NO-NAT for VPN.
between my call manager and router its on the same subnet of X.X.150.1 and X.X.150.7 but ip phone on X.X.155.7 but there is inter-vlan routing happening.
Did you press the question mark button on the phone to check the packet flow . It should provide a fair idea of whether the packets are going vice-a-versa.
Thanks.
So is there a firewall or VPN between the router and the IP Phones?
No there is no firewall, its all in the same segment.
i can check the question mark statistics tomorrow and update if its working or not.
is there any configuration issue???
