09-08-2013 07:38 PM - edited 03-16-2019 07:15 PM
How do I know whether my VoIP streams between telephony devices are TCP-based, or UDP-based?
Many Thanks
Senan
Solved! Go to Solution.
09-08-2013 08:06 PM
The RTP stream always use the UDP port range 16384 - 32767.
Gnan.
09-08-2013 08:06 PM
Gnan.
09-08-2013 08:19 PM
