Cisco Presence - chat history location
Hi Team,
I am using a CUPS Ver 8.0 integrated with a CUCM 8.0
Recently we had a problem, and I was asked (by management) to get the chat history of another employee from the cups server.
Do you know how i can get this and also, where this cache will be located. Any help will be appreciated.
Thanks and Regards,
Shabeeb
NB: CUPC versions in use are 8-0-1, 8-0-3 & 8-5-1
Jaime Valencia
From the server you would get that only if you had configured the postgresql server for such purpose.
java
if this helps, please rate
I dont think this has been configured.. could you guide me in doing this?? any document or links??
Shabeeb
You wont get anything before you configure it, thats lost, just search postgresql on cisco.com to get the documentation.
java
Thanks.. let me check this out..
Please let me know if there are any other methods to acheive this.
-Shabeeb
