Cisco Prime Unified Operations Manager 9.0 , device discovery configuration
Hello to all. Hope this mail finds all of you well.
I have a problem with a CUOM Prime 9.0 discovery configuration.
The customer's infrastracture is a cluster CUCM (VM), 9.1.2.
The CUCM cluster is up and running and all the cisco devices can be able to ping each other.
The customer wants to use a Cisco Prime Unified Operations Manager 9.0 in order to monitor all the Cisco devices.
The problem that I faced is that after the CUCM and CUOM 9.0 basic configuration,
in the CUOM 9.0 Device Management/Device Configuration, the discovery devices are "unreachable".
I have checked all the relative parameters and they seem to be ok.
Can anybody help me on that "CUOM device discovery" problem?
Thank you very much in advance.
Isidoros
Manish Gogna
Manish Gogna
Hi Isidoros,
Can you check the points mentioned in the following link
http://www.cisco.com/en/US/docs/net_mgmt/cisco_unified_operations_manager/faq/OMFAQ11.html#wp42542
Manish
Hello Manish.
Thank you for your help. It was a useful link.
Actually, the problem was a firewall problem.
Now, the CUOM device discovery works fine.
Isidoros A.
