08-18-2011 11:40 AM - edited 03-16-2019 06:33 AM
Please help me , I have problem with registering Cisco SIP phone 9971 with CME 8.6 on ISR 2901.
I configured CME for SIP clients, then I add configuration for 9971 phone and create profiles. Phone downloaded SEP...xml file from CME,after that phone look for g4-tones.xml and gd-sip.jar files, I added them to CME after that phone downloaded them and reboot. Now phone is stuck in some kind of loop and does not register on CME.
On phone log I can see repeting next few messeges.
12:01:58a No DNS Server IP
12:01:59a Updating Trust list
12:01:59a No Trust List instaled
12:01:59a SEP04C5AB03B0D.cnf.xml (TFTP) // at this time phone download SEP...xml file from CME
12:02:00a VPN Error: VPN is not Configured
on CME if issue DEBUG TFTP EVENTS i receive next few lines
*Aug 18 18:20:19.891: TFTP: Looking for CTLSEP04C5A4B03B0D.tlv
*Aug 18 18:20:19.987: TFTP: Looking for ITLSEP04C5A4B03B0D.tlv
*Aug 18 18:20:20.083: TFTP: Looking for ITLFile.tlv
*Aug 18 18:20:20.347: TFTP: Looking for SEP04C5A4B03B0D.cnf.xml
*Aug 18 18:20:20.351: TFTP: Opened flash:/SEP04C5A4B03B0D.cnf.xml, fd 14, size 4585 for process 141
*Aug 18 18:20:20.363: TFTP: Finished flash:/SEP04C5A4B03B0D.cnf.xml, time 00:00:00 for process 141
here you can see verison info of CME
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 24-Mar-11 15:31 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
ELTOSAN_ROUTER uptime is 1 hour, 50 minutes
System returned to ROM by reload at 16:29:20 UTC Thu Aug 18 2011
System image file is "flash:/c2900-universalk9-mz.SPA.151-4.M.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco CISCO2901/K9 (revision 1.0) with 471040K/53248K bytes of memory.
Processor board ID FGL1508252Y
3 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Survivable Remote Site Voicemail (SRSV) on Cisco Unity Express (CUE) 8.5.1 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2901/K9 xxxxxxxxxxxxx
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
this is RUNNING CONFIGURATION
! Last configuration change at 16:10:12 UTC Thu Aug 18 2011
version 15.1
hostname ELTOSAN_ROUTER
boot-start-marker
boot system flash:/c2900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp excluded-address 192.168.5.200 192.168.5.255
ip dhcp pool phone
network 192.168.5.0 255.255.255.0
default-router 192.168.5.251
option 150 ip 192.168.5.251
ip dhcp pool data
relay source 192.168.2.0 255.255.255.0
relay destination 192.168.2.201
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711alaw
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 192.168.5.251 port 5060
max-dn 6
max-pool 6
load 9971 sip9971.9-1-1SR1.loads
authenticate register
tftp-path flash:
create profile sync 0005135312289902
voice register dn 1
number 207
allow watch
name GossaVM
label 207
voice register dn 3
number 101
name Dejan
label 101
mwi
voice register pool 1
id mac 000C.29C5.0011
number 1 dn 1
dtmf-relay sip-notify
username testvm password testera
codec g711alaw
voice register pool 3
id mac 04C5.A4B0.3B0D
type 9971
number 3 dn 3
presence call-list
dtmf-relay rtp-nte
username dejan password 1234
codec g711alaw
no vad
license udi pid CISCO2901/K9 sn xxxxxxxxxxxx
hw-module ism 0
hw-module pvdm 0/0
redundancy
interface GigabitEthernet0/0
description INTERFACE INTERNAL
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.2
description LAN DATA
encapsulation dot1Q 2
ip address 192.168.2.251 255.255.255.0
no ip route-cache
interface GigabitEthernet0/0.5
description LAN VOICE
encapsulation dot1Q 5
ip address 192.168.5.251 255.255.255.0
no ip route-cache
interface ISM0/0
no ip address
no ip route-cache
shutdown
!Application: SRSV-CUE Running on ISM
interface GigabitEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community public RO
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn alias dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn alias kern9971.9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn alias rootfs9971.9-1-1SR1.sebn
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn alias sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn alias skern9971.022809R2-9-1-1SR1.sebn
tftp-server flash:sip9971.9-1-1SR1.loads alias sip9971.9-1-1SR1.loads
tftp-server flash:United_States/g4-tones.xml
tftp-server flash:English_United_States/gd-sip.jar
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password jebiga
login
transport input all
end
I did not have any kind of problem with X-LITE to register to CME. also try with few SCCP phones 7940 and I did not any kind of problem .
this is content of SEP....xml file for 9971
<device>
<deviceProtocol>SIP</deviceProtocol>
<devicePool>
<dateTimeSetting>
<dateTemplate>M/D/YA</dateTemplate>
<timeZone>Pacific Standard/Daylight Time</timeZone>
<ntps>
<ntp priority="0">
<name>0.0.0.0</name>
<ntpMode>unicast</ntpMode>
</ntp>
</ntps>
</dateTimeSetting>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<sipPort>5060</sipPort>
</ports>
<processNodeName>192.168.5.251</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<sipProfile>
<sipProxies>
<registerWithProxy>true</registerWithProxy>
</sipProxies>
<sipCallFeatures>
<cnfJoinEnabled>true</cnfJoinEnabled>
<localCfwdEnable>true</localCfwdEnable>
<callForwardURI>service-uri-cfwdall</callForwardURI>
<callPickupURI>service-uri-pickup</callPickupURI>
<callPickupGroupURI>service-uri-gpickup</callPickupGroupURI>
<callHoldRingback>2</callHoldRingback>
<semiAttendedTransfer>true</semiAttendedTransfer>
<anonymousCallBlock>2</anonymousCallBlock>
<callerIdBlocking>2</callerIdBlocking>
<dndControl>2</dndControl>
<remoteCcEnable>true</remoteCcEnable>
</sipCallFeatures>
<sipStack>
<remotePartyID>true</remotePartyID>
</sipStack>
<sipLines>
<line button="1" lineIndex="1">
<featureID>9</featureID>
<featureLabel></featureLabel>
<proxy>USECALLMANAGER</proxy>
<port>5060</port>
<name></name>
<displayName></displayName>
<autoAnswer>
<autoAnswerEnabled>2</autoAnswerEnabled>
</autoAnswer>
<callWaiting>1</callWaiting>
<authName>dejan</authName>
<authPassword>1234</authPassword>
<sharedLine>false</sharedLine>
<messagesNumber></messagesNumber>
<ringSettingActive>5</ringSettingActive>
<forwardCallInfoDisplay>
<callerName>true</callerName>
<callerNumber>true</callerNumber>
<redirectedNumber>true</redirectedNumber>
<dialedNumber>true</dialedNumber>
</forwardCallInfoDisplay>
</line>
<line button="2" lineIndex="2">
<featureLabel>101</featureLabel>
<port>5060</port>
<name>101</name>
<displayName>Dejan Rakic</displayName>
<autoAnswer>
</autoAnswer>
</line>
</sipLines>
<enableVad>true</enableVad>
<preferredCodec>g711alaw</preferredCodec>
<dialTemplate></dialTemplate>
<kpml>1</kpml>
<phoneLabel></phoneLabel>
<stutterMsgWaiting>2</stutterMsgWaiting>
<disableLocalSpeedDialConfig>true</disableLocalSpeedDialConfig>
<dscpForAudio>184</dscpForAudio>
<dscpVideo>136</dscpVideo>
</sipProfile>
<commonProfile>
<phonePassword>1234</phonePassword>
<callLogBlfEnabled>2</callLogBlfEnabled>
</commonProfile>
<featurePolicyFile>featurePolicyDefault.xml</featurePolicyFile>
<loadInformation>sip9971.9-1-1SR1.loads</loadInformation>
<vendorConfig>
</vendorConfig>
<commonConfig>
<videoCapability>0</videoCapability>
<ciscoCamera>0</ciscoCamera>
</commonConfig>
<sshUserId>dejan</sshUserId>
<sshPassword>1234</sshPassword>
<userId></userId>
<phoneServices>
<provisioning>2</provisioning>
<phoneService type="1" category="0">
<name>Missed Calls</name>
<url>Application:Cisco/MissedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Received Calls</name>
<url>Application:Cisco/ReceivedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Placed Calls</name>
<url>Application:Cisco/PlacedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<phoneService type="2" category="0">
<name>Voicemail</name>
<url>Application:Cisco/Voicemail</url>
<vendor></vendor>
<version></version>
</phoneService>
</phoneServices>
<versionStamp>0131511014412102</versionStamp>
<userLocale>
<name>English_United_States</name>
<langCode>en</langCode>
</userLocale>
<networkLocale>United_States</networkLocale>
<networkLocaleInfo>
<name>United_States</name>
</networkLocaleInfo>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<servicesURL>http://192.168.5.251:80/CMEserverForPhone/serviceurl</servicesURL>
<dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>
<dscpForCm2Dvce>96</dscpForCm2Dvce>
<transportLayerProtocol>2</transportLayerProtocol>
</device>
08-18-2011 12:16 PM
Is that the entire CME config? I'm not seeing any telephony configuration.
Unless things have changed drastically since 8.0, you need to specify what load to use for each phone type.
Example:
! telephony-service no auto-reg-ephone load 7960-7940 P00307020300 max-ephones 144 max-dn 500 ip source-address 172.22.1.107 port 2000 max-redirect 15 service phone videoCapability 1 dialplan-pattern 1 5123781291 extension-length 4 voicemail 2000 max-conferences 8 gain -6 transfer-system full-consult secondary-dialtone 9
Config example:
Compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme85spc.htm.html
08-18-2011 03:25 PM
I left that part of configuration, I was thinking that was not important for registering SIP phones
here is it:
telephony-service
no auto-reg-ephone
max-ephones 24
max-dn 72
ip source-address 192.168.5.251 port 2000
calling-number initiator
timeouts interdigit 2
timeouts busy 5
system message ELTOSAN
cnf-file location flash:
load 7906 SCCP11.8-4-2S.loads
time-zone 26
time-format 24
date-format dd-mm-yy
voicemail 555
mwi relay
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin password xxxxxx
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
create cnf-files version-stamp Jan 01 2002 00:00:00
08-18-2011 04:16 PM
You need to add a load statement for the 9971 phones. You have one for the 7906 model but you need to remove the .loads at the end so it reads:
You'll need to add:
Once you go into telephony config mode type "load ?" and it will list all the supported phone types.
Edit: You may want to do a no cnf files/create cnf files once you make the change.
08-19-2011 02:36 AM
I do not have in "Telephony Service" loads for 9971 phone because phone is SIP not SCCP phone, in "Voice register global" i have option for loads for 9971 phones.
08-19-2011 07:06 AM
My bad. I haven't used SIP phone on CME so I assumed (bad idea!) the config was the same. I did some research and it looks like the same rule applies and you need to remove the .loads from your load statement uner voice register global.
Also, is there are reason all your tftp entries have an alias listed with the same name? You may want to clean that up to make sure. Other than that I'm not sure.
08-20-2011 01:38 AM
I remove loads from "Voice Register Global " , same problem , I also try with reseting to factory setting phone. Same issue .
Is it possible to have some kind debug on the phone?
Which files phone need to download from TFTP if I have load statment ?
I am confused. When I reset phone to factory and I look in the tftp debug i can see that only three files are downloaded.
*Aug 20 08:06:11.055: TFTP: Looking for CTLSEP04C5A4B03B0D.tlv
*Aug 20 08:06:11.159: TFTP: Looking for ITLSEP04C5A4B03B0D.tlv
*Aug 20 08:06:11.255: TFTP: Looking for ITLFile.tlv
*Aug 20 08:06:11.395: TFTP: Looking for SEP04C5A4B03B0D.cnf.xml
*Aug 20 08:06:11.399: TFTP: Opened flash:/SEP04C5A4B03B0D.cnf.xml, fd 14, size 4579 for process 93
*Aug 20 08:06:11.463: TFTP: Finished flash:/SEP04C5A4B03B0D.cnf.xml, time 00:00:00 for process 93v
*Aug 20 08:06:14.771: TFTP: Looking for English_United_States/gd-sip.jar
*Aug 20 08:06:14.779: TFTP: Opened flash0:English_United_States/gd-sip.jar, fd 14, size 75616 for process 93
*Aug 20 08:06:15.159: TFTP: Finished flash0:English_United_States/gd-sip.jar, time 00:00:00 for process 93
*Aug 20 08:06:17.995: TFTP: Looking for United_States/g4-tones.xml
*Aug 20 08:06:18.003: TFTP: Opened flash0:United_States/g4-tones.xml, fd 14, size 1915 for process 93
*Aug 20 08:06:18.015: TFTP: Finished flash0:United_States/g4-tones.xml, time 00:00:00 for process 93
None of the *.loads and *.sebn files was requested by the phone. I presume that phone see in configurationfile that 9.1.1 firmware is loaded on CME and compare with his firmware version, if are the same version, phone does not try to download them.
Do you have any idea how to generete this TLV files
Today I will try to two things.
first I wil try newes firmware 9.2.1 and debug whole process
second I will convert one of the 7906 to SIP protocol to see does it work with 7906 over SIP..
If you have any idea , I will be very grateful.
10x in advanced.
08-20-2011 05:38 AM
I'm not sure on this one. Those .tlv files seem to have the phone name in them (SEP04C5A4B03B0D) so I'm assuming it's looking for specific config info.
11-11-2015 06:01 PM
Donwload and install new locale. This issue is related with the process:
CME SIP configured -> CME SIP removed -> CME SIP configured again
copy tftp://x.x.x.x/CME-locale-xx_XX-Xxxxxx.tar flash:/its/
02-24-2016 04:18 PM
I have the same Problem. Reinstalling the same locale as bevor? My 9951 dont Register after adding a sip-ua trunk.
HELP!
08-20-2011 11:02 PM
Your configuration is correct.
You do not need to have telephony-service for SIP phones as it is used for SCCP Phones only.
You need to use voice register global instead which is the SIP subsysted for CME.
Try binding SIP to correct interface for Voice VLAN and take debug ccsip messages. You should see SIP Register message from the phone.
Please provide the debug output.
Udit
08-21-2011 02:43 AM
One stupid question . How to bind SIP to interface. Is it command in "voice register global" "source-address 192.168.5.251 port 5060"
I try to debug ccsip messages but i do not receive any message for phone 9971 , I receive only messeges for XLITE client on data VLAN (2). I tryed to convert one 7906 from SCCP to SIP and now i get similar behvor with message on display "unprovisioned". I think that something is wrong in my configuration but i do not know what is it.
probably you are right i did not bin SIP to corect VLAN 5 interface but i do not know how I did it for data VLAN 2 interface becouse XLITE work over SIP
please help me
10x in advanced
08-21-2011 11:12 AM
Use the following command to bind SIP to an interfaace -
voice service voip
sip
bind all source-interface
Udit
08-22-2011 11:10 AM
Binding SIP to interface did not help , but I solved problem.. I start from scratch, I reset to factory router , then manualy configure whole CME. After adding phone 9971, phone register without problem . I compare configurations . I saw my mistake .
in first configuration i did not configure line 1
type 9971
number 3 dn 3 <- mistake
second time i configure
type 9971
number 1 dn 3
one stupid mistake
10x any way
08-22-2011 11:14 AM
It's great you got it working!
You helped me learn a bit about SIP in an CME environment.
Thanks!
