01-19-2016 11:50 AM - edited 03-17-2019 05:33 AM
Dears
I have issue with Cisco 7961G connect to cisco 3524 XL switch.
I found that the phone doesn't get POE , so i get external Power for it.
so now I connect the phone to this switch and phone get the external power . the port of the switch is NOT blinking .
I try to register the phone to CME router ( I upload the firmware to flash ) but the port itself not blinking .. i try with different ports.. but it still the same.
is there any idea to resolve this issue.
thanks
01-19-2016 11:57 AM
You need to look at port configuration.
can you please post the output of switch port config?
Carlo
01-19-2016 12:05 PM
it is normal config
all the ports are assigned into default vlan
Switch#show run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 10.1.1.254 255.255.255.0
ip helper-address 10.1.1.252
no ip directed-broadcast
no ip route-cache
end
01-19-2016 12:11 PM
thanks for the output.
Please attach also a show cdp neighbor
show interface status
Carlo
01-19-2016 12:29 PM
Switch#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
PSTN Fas 0/9 168 R S I Cisco 2811Fas 0/0
HQ-VG Fas 0/1 162 R S I Cisco 2811Fas 0/0
phone connect to power fa0/11
Switch#show interfaces status
Port Name Status Vlan Duplex Speed Type
Fa0/1 connected 1 A-Full A-100 100BaseTX/FX
Fa0/2 connected 1 A-Full A-100 100BaseTX/FX
Fa0/3 connected 1 A-Full A-100 100BaseTX/FX
Fa0/4 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/5 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/6 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/7 connected 1 A-Full A-100 100BaseTX/FX
Fa0/8 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/9 connected 1 A-Full A-100 100BaseTX/FX
Fa0/10 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/11 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/12 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/13 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/14 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/15 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/16 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/17 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/18 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/19 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/20 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/21 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/22 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/23 notconnect 1 Auto Auto 100BaseTX/FX
Fa0/24 notconnect 1 Auto Auto 100BaseTX/FX
Gi0/1 notconnect 1 Auto 1000 Missing
Gi0/2 notconnect 1 Auto 1000 Missing
Switch#show interfaces status fa
Switch#show interfaces fa
Switch#show interfaces fas
Switch#show interfaces fastEtherne
Switch#show interfaces fastEthernet 0/11
FastEthernet0/11 is down, line protocol is down
Hardware is Fast Ethernet, address is 000d.2912.834b (bia 000d.2912.834b)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex , Auto Speed , 100BaseTX/FX
Last input never, output 00:45:32, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
1 packets input, 64 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast
6 packets output, 2059 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
01-19-2016 01:20 PM
is there any one can help me out in this issue?
01-19-2016 05:48 PM
Hi.
Sorry for delay
On fa0/11 add this config
speed 100
duplex full
switchport mode trunk
Let me know
Carlo
01-19-2016 09:22 PM
thank you for cooperation
still NOT work
the port not blinking
01-19-2016 10:15 PM
I am not sure if the phone is faulty or not getting the right watts from the external power supply but the switch port is showing disconnected which means that the switch isn't sensing the carrier signal from the phone.
Do the following
1. Apply the following commands:
config t
logging monitor debug
logging on
default interface fa0/11
interface fa0/11
switchport mo acces
sw port access vlan 1
sw port voice vlan 1
no shut
speed auto
duplex auto
2. turn on 'term moni'
3. Unplug the phone and plug it again
4. Check what logs popup on the switch
01-19-2016 10:37 PM
Have you connected the Ethernet cable into the correct port on the phone?
do any LEDS light on the phone when you use the external P/s?
what is the external p/s output? should be 48VDC
also the 7961G will work with pre-standard poe which is supplied by the 3524 as long as the model is 3524-PWR-XL
01-20-2016 12:17 AM
the power external is 48DCV and the phone get power from the external and the phone screen shows that it try to make upgrade.
and this is version of the switch
cisco WS-C3524-PWR-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
01-20-2016 01:17 AM
ok the 3524 will support poe for the 7961G
please do a show power inline to see if power available.
you are using an Ethernet patch cord with connections as pre-standard poe uses unused wires
01-20-2016 01:39 AM
dear
in the begining when i connect the phone to the switch , i found the phone not working at all and the port of switch NOT blinking , nothing appear on the screen. so I buy external Power for this phone 48DCV.
Now ; the phone have LED and the screen shows that it try to upgrade but the Cisco Switch PORT is NOT Blinking .
so why the port is not blinking.?
i use straight cable for the connection.
01-20-2016 12:15 AM
dear
i follow yours steps and nothing popup on the switch screen.
01-20-2016 12:32 AM
Change the cable. If didnt work then phone might be faulty
