IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5409 Views
  • 14 replies
We're deploying 50 IP phones and a new 2921 gateway with an FXS card. I have all the phones configured, but need to add three analog fax machines to the gateway. These machines will be directly attached to the 2921 via FXS card. How can I configure t...
Hey, guys. Can anyone provide simple "how to" for Corporate Directory service? I'd like for users to be able to open the directory on phones and located users extensions. I've synced to LDAP under "directory number alias lookup and sync". I'm unable ...
A question regarding what different between PVDM 4 that installed on Motherboard and on NIM card . The below note from cisco There is only one PVDM slot on the motherboard. The Time Division Multiplexing (TDM) cards can not use the motherboard PVDMs....
yun zhang by Level 1
  • 2796 Views
  • 1 replies
hello all,  i have intergrted  cumc 10.5.2 and paging 9.1.1 .when i dial paging no, all the phones speakers are lightup as  expected, we are not able to carry voice brodcast over the phone. issue seems to be with mutlicast routing as per google  .any...
Resolved! Multiple FXO ports
Hi everybody, Ours is a very small setup with only one outside line connecting to voiceport,  we are having auto attendant configured. Now we are adding one more FXO line to our network, but when call comes on that line, all the calls should be forwa...
1- 3905 , the status stuck on registration and when we tried to access the setting it asked about passowrd? 2- 7821: stuck on registration , when we press setting we got XML Parse Error[4] 2911 , cme 10.5 we have issue on registration the following:...
mkhriesa by Level 1
  • 652 Views
  • 7 replies
Hi, We have a project of creating a seprate subnet for VOIP phones where we are having some issues and need some assist. In current scenario, the VOIP phones, VOIP Server and the machines are placed on default VLAN (1) (192.168.1.1/24) where the GW o...
