05-13-2020 09:16 AM
Hello everyone, hope all is well !!!
I have MS Teams and Cisco UCM and Cisco UCCE in my environment. I have users requesting if there is a way for Teams to call a Cisco desk phone extension and vice versa, and also if Cisco UCCE agents can take calls using Teams. Has anyone been through this scenario ? I am running CUCM 10.5 and UCCE 10.5
Thanks in advance !!! I very much appreciate any inputs / suggestions !!!
Danny
05-13-2020 12:39 PM
You can setup a SIP trunk between your envirnment and MS Teams using their direct routing. That will allow you to send calls to MS Teams.
You can receive UCCE calls via this link as well using mobile agent.
There are caveats but generally, the answer is yes.
05-13-2020 01:23 PM
Hi Steve,
Thanks Steve !!! I appreciate your response !!!
Do you have any document you can share ?
Thanks !!!
Danny
05-13-2020 01:58 PM
I havent seen anything specific but this doc might be useful.
05-13-2020 03:34 PM
Thanks Steve !!! very much appreciate your help !!!
I am running CUCM 10.5 hope it will work.
Thanks !!!
Danny
05-13-2020 10:02 PM
Direct routing works with other MS approved SBC and not just audio codes. This include oracle SBC.
Here is the official documentation on direct routing..
https://docs.microsoft.com/en-us/microsoftteams/direct-routing-plan
05-15-2020 07:25 AM
If I remember correctly Cisco CUBE is expected to become approved for Direct Routing. Again from memory I believe the context for that approval is for PSTN access, and not necessarily extended to routing between CUCM and Teams.
05-15-2020 10:04 AM
Hey Tony,
That will be the day! I will be utterly shocked if MS approves CUBE...Direct routing is also provides PSTN access. The idea is that your SBC will connect to your ITSP for PSTN connectivity and MS applications will use it for accessing PSTN
05-15-2020 10:11 AM
yes, the "approval coming soon" feels a lot like "Half-Life 3 is in development"
sounds great but i just dont believe it anymore.
