Hi all, I am trying to configure within CUCM a forward within office hours and then a different forward out of hours.DN is 4460in hours this needs to forward to 5888and out of hours this needs to forward to 4470 Could anyone help please ?
Hello,I'm having issues with the phones in the same cluster. It gets stuck to registering and gets rejected after the phone reboots.We successfully upgraded our CUCM from 11.5 to 12.5 a week ago.CUCM cluster filled up the active partition to 98% afte...
Hi all, if I have 2 CUCM servers, can I make 1 of the CUCM servers as publisher and subscriber and another CUCM server as subscriber? Or it can only be 1 publisher and 1 subscriber?Thanks.
Hi, Our cisco phones keep freezing around every 6 weeks, the phones we have are CP-8841-3PCC and they appear to be on the latest firmware as the software version is sip88xx.11-3-1MPP-697.loadsHas anyone else had this issue and does anyone know of a f...
Hi, We are having an issue with CLID when calling via PSTN network. Below is the telco log for reference unable to understand the issue.2020-08-10 16:05:02.020370 [DEBUG] isdn_trace.c:224 [SNGISDN Q931] wp11 FRAME INCOMING: Prot Disc:Q.931/I.451 (0x...
Hello,I am working at a customer with CUCM 10.5 who uses MGCP gateways to access the PSTN via T1 PRI ISDN.They use four digit DNs internally and need to prefix these with 713657 to make the outbound CLID work ok - i.e. a call to the PSTN from extensi...
Can I have 1 extension registered to multiple phones with sip firmware on it not sccp?
Im a home user wanted to test IP Phones, should have gone for an easier phone now... So i brought a 7960 phone they installed SIP before sending it to me, I have registered with SIPGate and need to change some settings into the SPA web Configuration....
Dear Sirs,I have an issue with preinstalled CP 6941 / with active load SIP9.4.1.3.SR3After reset, this guy request CTL, ITL, ITL file, and only then cnf.xml.Сertainly 'phone not registered'.Asterisk - 0 online, 0 offline.In general, I confused should...
Hello all, I am trying to create a new SIP trunk to my cubes individually to service a new need in the organization. Pass DTMF via a call consult transfer within UCCX. The goal is to pass the account number and PIN into a distant IVR. We have found t...
Hello, I was following this guide for troubleshooting a problem with some phoneshttps://www.cisco.com/c/en/us/support/docs/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/9495-isdn-q931-ts.html the status "setup...
This is a LDAP enabled system and I have checked the LDAP and it appears to be syncing correctly.I have to use the locally defined administrator account to login.This was working, however, I am currently unable to login to my Inbox or the Cisco Unit...
Is it possible to configure SIP settings on an 8832 phone? Right now it works fine in CUCM however I need to use it at a remote office that's not on our network. Our phone carrier can give me SIP settings however there doesn't appear to be any way ...
Can we have to enable call forwarding in schedule based, Like today I need to forward to 1001 for tomorrow to 1002 like that in cucm We have cucm and cuc 11.5
Running CUCM 10.5 Looking to delete phones as we are charged for them however, would like the calls to continue going to voicemail even though phone is deleted. Thought calls would continue to flow as long as the directory number was in the system. A...
Subject | Author | Posted |
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
