Cisco UCM on AWS/Azure Cloud & HCS
prakashsatya
Is there any way we can deploy Cisco UCM on AWS/Azure Cloud ?
can somebody guide me how to HCS system gets deployed on Cloud ? is it only deployed & maintained by Cisco ?
Satya
As already explained, what is in the virtualization wiki as supported platforms and virtualization options, is what is supported. Anything that is NOT MENTIONED is assumed as NOT SUPPORTED.
java
if this helps, please rate
Jaime Valencia
The requirements and compatible hypervisors/options for the UC products are in the virtualization wiki, only what is shown is compatible and supported.
Partners can also offer HCS
https://www.cisco.com/c/en/us/solutions/hosted-collaboration-solution/index.html#~stickynav=4
https://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/hosted-collaboration-solution-hcs/hcs_aag.pdf
Have you read any documentation around HCS?
java
Thanks for reply Java
those docs you provided is HCS based .
I am looking something we can deploy UCM on cloud other than HCS
is there any way Cisco Supports those deployments on Azure/AWS ?
Satya
java
Thanks Again,
Not Supported i suppose .
