Cisco Unified Call Manager Express support for 8800 side car
jerecassidy
The CUCME data sheet does not show support for the following item:
Cisco IP Phone 8800 Key Expansion Module
CP-BEKEM=
Also the item's data sheet itself mentions CUCM and SRST, but does not mention CUCME specifically.
Can someone confirm that it is not supported?
It seems the only option for a reception phone with the current models would be the 7861 with 16 buttons built-in (no side car).
Also an option would be to go back to a 7945 or 7965 with the 7915/7916 side cars.
Thanks in advance.
Manish Gogna
It is definitely supported but looks like it is not updated in the documentation yet, a sample config to make it work would be the following
voice register pool-type 8851
xml-config maxNumCalls x
xml-config busyTrigger x
phoneload-support
num-lines x
addons 1 description Cisco SIP Phone 8851
reference-pooltype xxxx
voice register pool x
type 8851 addon 1 CKEM
Manish
