04-15-2013 01:17 AM - edited 03-16-2019 04:47 PM
I would like to know whether I can host Cisco Unified Communications on the following IBM Blade Server Platform:
Thank you.
04-15-2013 01:21 AM
HI
Below are the supported servers for Cisco CUCM
Below are supported server for Virtualization
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware
I dont think above two server are suported.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
04-15-2013 07:33 AM
Look at Spec Based requirements on the link provided by Ronak, spec based does not list specific servers but rather outlines what the specs of the HP/IBM/Dell/etc servers need to be. As long as your hardware is within those specs you are OK. Also, take a note of VMware licensing requirements for spec based deployments.
HTH,
Chris
