Cisco Unified IP Conference Phone 8831 cnf.xml file provisionning from template source
vpancisco
hello world,
I'm trying to provide configuration file SEP$MACcnf.xml from a tftp server
My CP-8831 read the file but still stay not registered.
does any one had face to this problem ...
regards,
To manually enable the web access you may change the tag <webAccess> under the XML file.
The value <webAccess>1</webAccess> means that the Web Access is disabled
The value <webAccess>0</webAccess> means that the Web Access is enabled
5 Replies 5
Gilmar Silva
If the web access is eneblad in the configuratioin file, you will be able to see some informations under the links status messages, console logs and debug.
What are the call control (CUCM, CME, Third party)?
Gilmar Silva
Third part with cisco official template file configuration
George Sotiropoulos
Can you enable the web interface on the Phone (if you are in Cucm enviroment) and check the Network and Log files of the CP-8831?
Hope the above helps,
gsotirop
It looks like java bug xml parser
