Cisco Unified IP Phone CP-7965G
CISCOTUMBA
Hello Everyone,
We have Cisco Unified CM Administration that manages our phone system. I have a phone that is locked by UCA and I want to assignee manual IP address on it but there is a lock on the setting and doesn't let me to change anything.
Before I hadn't have access to setting at all but under this setting I enabled the management key.
  1. Open CallManager Administration page.
  2. Go to Device -> Phone and select the affected phone.
  3. Go to Phone Configuration Page and  find Settings Access under Product Specific Configuration Layout.
  4. Set it as "Enabled".
  5. Reset phone.
So how can I now fix assigning IP on the phone?
Go into the Settings menu. Then press **# to unlock the menus, allowing configuration. When you are done, press **# again to re-lock (as the menu does not re-lock automatically even after a reboot).
Note that this key sequence is different than the **#** used to reboot the phone.
Maren
Maren
Thank you Maren!
