Cisco Unified Mobility & CFA feature interaction in 9.1
jgovin
I have Mobile Connect feature enabled on Phone A and it is linked to a remote device==>Mobile Phone. I enabled CFA on Phone A==>Phone C. When Phone D calls Phone A, call is forwarded to Phone C. It did not ring the remote device. Is this a normal behavior?
Thks
Jeya
8 Replies 8
Shashank Mahajan
Hi Jeya,
It should ring Phone A and the mobile number specified as its remote destination for an incoming call. If it's not ringing the remote destination/mobile number then it means probably the mobility is disabled.
Shashank
Thks for your response. Mobility is enabled for that DeskPhone. I just enabled CFA on the Desk Phone and tried the call to it again.  When I disable CFA and make the call to the Mobile User's desk phone, the remote device is ringing...
Is there any Service Parameters that I need to check for this feature to work?
Thks
Jeya
Seems to be working as designed. It is worth giving a try in the LAB.
Abhay Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Hi Abhay,
What u mean by seems to be working as designed? Am I missing any configuration... like some service parameter settings?
Thks
Jeya
This is normal behaviour and i have tested this.
If CFA is set on the device then it will forward to that number and will not ring remote device.
Please rate helpful posts.
So Shasmaha's comment was not accurate? Do you have any documents that specifies that is the case?
Because in SRND 9.1, it mentioned the following:
Impact of Session Handoff on Other Features
When the user hands off a call, a new call gets presented on the desk phone. While the desk phone is flashing,
the following features do not get triggered on the desk phone for the call that was handed off:
iDivert
Call Forward All
DND
Call Forwarding
Question: If it does not ring the remote device, how then a remote device receives a call in the first place to  handoff a call when these features were enabled on desk phone?
Thks
Jeya
I am confused with the description and question you are asking .
Please pardon me.We might need a web ex to understand what you are testing here.
Your original question was Device A has Call forward all on- to a another destination and it also have a remote destination.So why remote is not ringing ?
Answer as per my testing was  if  call comes it device A now , call will go the the call forward destination not to remote destination.
Sorry for the confusion. Whatever you tested is what I am also seeing during my testing. Remote device does not ring when CFA is enabled on desk phone.
Question:
1) Is the any Cisco document that talks about CF & Mobility feature interactions?
    I checked the Feature & Services Guide and did not see any mention of their  interaction behavior
2) How do you test the scenario from the SRND 9.1 section I pasted in my previous reply?
I am OK with a webex if I confuse u again. :-)
Thks
Jeya
