Cisco Unity Connection 1.1(1) SR1 no Admin Web Page
ben-sharpibm
I have a cisco unity MCS7800 server. Everything is working fine as far as the phones are concerned however I cannot access the core "Connection Administration" at https://localhost/cuadmin or "Connection Configuration Assistant" at https://localhost/ccua. I have restarted the server multiple times, I have tried a few other things but to no avail.
I have got the following in application events:
Event Type: Error
Event Source: CSAgent
Event Category: Kernel Rule
Event ID: 256
Date: 9/1/2008
Time: 10:20:57 AM
User: N/A
Computer: NAME
Description:
The process 'System' (as user NT AUTHORITY\SYSTEM) attempted to communicate with 10.70.30.1 on TCP port 139. The attempted access was to accept a connection as a server (operation = ACCEPT). The operation was denied.
If anyone has seen the above, or has any information that could help it would be much appreciated!
Jaime Valencia
have you tried to disable CSA??????
java
if this helps, please rate
java
Yes I have tried that, even re-installed it.
